My Rotten F150 Project
Thanks, RTM.
As you can see from the pics below, the truck is in pretty decent shape... except for the last 12" of the frame.
Hank Bagrowski from Hank Bagrowski Customs is fabricating some replacement steel for the frame. Those should be here Tuesday, hopefully.
I'm cutting the frame back 18" from the end, just to be sure. It's also the point where it would start to bend, and complicate the process.
Although dirty from out wonderful NE weather, the frame is REALLY solid up to that point; so to keep it that way, it'll be cleaned up and given a nice thorough undercoat.
Meanwhile, I'm going to replace the shocks, since they're so easy to get to right now.
The spring perches will be replaced with custom fabricated ones, but I'm going to get the frame back together first.
RTM, part of why I'm fabricating custom hangers is because I'm going to raise the truck 4" with them.
Below is the 4"x12"x3/16" mending plates I'm going to use. They're 304 stainless... I guess they'll last awhile. The holes will allow for plug welds, so it won't be welded just on the perimeter.
Oh, and these were "free"- or rather, I've had these kicking around for about 20 years or so. Time to get some use out of 'em.
Ep, once the steel gets here I'll start back to work on it. Should be here Tuesday. I'll be taking more pics, and adding them. I'll definitely keep ya guys posted!
Stainless is alot more corrosive resistant than carbon steel, how much more depends on the alloy. 302 and 304 more, and 305 or 316 being less so.
For some strange reason, I don't see it as a "big" project... either I'm overly optimistic... or I'm good. Dunno which yet...LMAO!
I learned the fabrication craft as a welder at a concrete plant. Sometimes we'd have to crawl under poured molds with a flashlight and a stick welder and shore up concrete-caked supports that were failing. Man, I guess compared to that this ought to be a breeze!
