Top End Oil Pressure 2.8
I think the oil is sent throught the head/block
surface on the 2.8L, if you've got no oil in the
rocker shaft, the cam bearing may have spun,
or was incorrectly installed, you may have to
pull the cam and drill down through the bearing
to get oil to travel up through the head...
The other possibility is that you have the wrong
rocket shaft stand and bolt installed for the oil
passage...
passage...
