fuel problem
Old Jan 14, 2004 | 05:15 PM
popee's Avatar
popee
fuel problem
hi
86 ranger fuel pump in tank not running. hi pressure pump is running.does not start because of this. any suggs ? I could really use a wiring diagram for this truck anyone know a site to get one
is there a site to look up wiring diagram for reference and view them thanks for any help
Old Jan 14, 2004 | 07:29 PM
Dealford's Avatar
Dealford
Welcome to FTE popee.
I don't have that wiring diagram. Maybe another member does. When you do get one, you can hot-wire the pump before you pull it out.
Ken00's Avatar
Ken00
Welcome to FTE!!!
Without the low pressure pump in the tank working the high pressure won't deliver fuel, they push MUCH better then they pull. Don't run the HP pump until you get the other one fix, you will overheat the pump, the fuel cools them. I'll drop you an email so you can send me your email address and then I can send you a diagram. Also pull the bed off to change the pump, much easier than dropping the tank.
Old Jan 14, 2004 | 09:15 PM
popee's Avatar
popee
ken
thank for help I cant get my email add to you because I am new
member The problem is both pumps work if jumpered directly
---so problem must be in wiring or relays if you can email me
schematic that would be great. is there a site for this for reference??? thanks again to all
popee
Old Jan 15, 2004 | 03:03 PM
Ken00's Avatar
Ken00
Check your mail, I need you to email me back because I can't attach files to FTE mail.
wohurst
Jun 7, 2015 09:55 AM
airborne0130
Feb 25, 2015 04:53 PM
BURNSTOUGHFORD
40
Mar 27, 2013 05:22 PM
markmc60
Large Truck
Aug 19, 2011 09:03 PM
