hey,
i was reading a mag the other day and came across a article about the '93 lightning w/ the 351W. afterwards, i got to thinking, what is the likelyhood of CORRECTLY swapping the supercharger or turbo or whatever from lightning 351 to my '93 bronco 351W? is it worth pursuing? most importantly, will it work?
____________________-
1993 bronco xlt 351W
well the motors are the same so fitment wont be an issue. the only worry i would have is with the speed density that you currently have and what the lightning used. swiching over to mass air would cure that problem of course but that would add around 500 bucks to the project at least.
