1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Tires?
Old 08-27-2002, 03:43 AM
dgodude's Avatar
dgodude
dgodude is offline
Tires?
Does anyone know if 285/75/16 tires will fit on a stock 2002 F250 SD 4x4,BFT without rubbing? The stock tires are 265/75/16 and I want to reduce the gap in the wheel well.
Old 08-27-2002, 07:20 AM
ForDen's Avatar
ForDen
ForDen is offline
Tires?
Yes they do fit. There are members that run up to a 315/ I believe, not sure if those are in spec, or will still have the same hauling capabilities. But you are safe with the 285's. Happy modding!
Old 08-27-2002, 11:59 AM
slammer's Avatar
slammer
slammer is offline
Tires?
yes they will.. I have them on my truck and have had no problems at all with rubbing or bottoming out. Besides they seem to fill the wheel well a bit more than the 265's
JMO,
Old 08-27-2002, 03:34 PM
Oldchap's Avatar
Oldchap
Oldchap is offline
Post Tires?
Go for it! I put BFGoodrich 295/75R AT-XO's on my 1999 F-250 4x4, and they fit great. Plus they look really great, and best of all I haven't gotton stuck in the mud since I put them on! Can't say that about the factory Generals that the truck came with, tho they gave me 85,000 miles, so I can't really complain.
The speedometer reads about 6 or 7% low (compared to a GPS unit), and my mileage went up about 10%. The tire dealer said I was pushing the limit using the stock wheel width size, so maybe I'll wear out the center a little earlier than the edges.
On extreme turns, they come real close, but do not hit anything. The AT's don't handle quite as good on the highway as the old highway type generals did, but I expected that. No big deal.
Definitely worth it!
Old 08-28-2002, 02:57 PM
dgodude's Avatar
dgodude
dgodude is offline
Tires?
Thanks guys for your help. I put on some 285 yokohamas on and they fit great. The trucks also looks better
Old 08-28-2002, 09:04 PM
Yeti's Avatar
Yeti
Yeti is offline
Tires?
Old 08-29-2002, 02:46 PM
Y2K350's Avatar
Y2K350
Y2K350 is offline
Tires?
I put the 285/75/16 on mine and wish I had gone a little bigger. I think the 315's probably would have fit without rubbing. I still think the 285's don't fill the wheel well as much as I would like. I have to keep load ratings in mind also considering the 12,000lb 5th wheel with an 1800lb tongue that I pull.
I went by one of those digital speedometer that D.O.T. puts on the side of the road and my speedometer was dead on with what it said I was doing.
2000 F350SD,SRW,RC,5spd man,V10, Front Leveling Kit,4.30 gears, 285/75/16 Wild Country
Old 08-29-2002, 05:13 PM
79CEEJAY's Avatar
79CEEJAY
79CEEJAY is offline
Tires?
I know guys running 295's and 305's all day long on stock rims. Although the 305's wear a little funny and have to be squeezed on the rim, they do fit. I am going with BFG 295's on my S/D soon. I think the factory alum wheels look GOOD, so I have no reason to change them out. Hope the 295's give good life........Anybody have any concerns with 295's??????
Old 08-29-2002, 11:58 PM
DPtoo's Avatar
DPtoo
DPtoo is offline
Tires?
What's the tallest tire that can be run on a bone-stock 4x4 Superduty? If I were to deal with recal-ing the speedo/odo, I'd sure prefer to jump up to 35" from the OEM 31 inches and change.
I'd be interested in a tall narrow tire with roughly the same load rating as the OEMs.
Old 08-30-2002, 04:45 AM
V10man's Avatar
V10man
V10man is offline
Tires?
You may want to check out the 255x85x16 size. They are 33" tall, 10" wide and have a 7.5" tread. They'll fit on stock wheels.
my91stealth
27
12-10-2010 01:29 AM
2Quik4u
1997 - 2003 F150
07-23-2010 09:51 PM
The Grinch
11-24-2009 06:31 PM
Saxon
11-17-2004 12:00 AM
zarillus
1997-2006 Expedition & Navigator
09-20-2004 03:45 PM
Quick Reply: Tires?
