miles on your 4.9
#166
1980 F100 372,000 miles
I gave my red 1980 F100 away to one of former owners in June of 2003. It had just over 372,000 miles on it. I bought it in 1999 with 350,000 on it. Didn't smoke or burn oil. It did have couple of leaks though. The distributor was froze, so couldn't time it. I had to do minor work to it to get it on the road. The new owner had to retire it after a hail storm though. No more winshield.
I was the fourth person at where I work to own that same truck.
I bought a " like new" 1996 F150 with just 96,000 on it last June as a replacement. It has 5.8L, let's see how far it goes... different forum too..
Kraig
Kraig
#174
#175
#176
Miles on F250
Hi everyone, new user here. I have a 91 F250 4wd with this inline 6. I am at 242k right now. Still runs great. Use the heck out of this truck. Tows my snowmahines, camper etc. I run synthetics. Motor has never had any major work. Just a water pump and alternator. Oil consumption is nil.
#179
1988 F250 4x4, service history.
Replace clutch disc every 100k due to repeatedly damaged center springs.
200k new injectors, chrome exhaust seats added to fix valve sealing problem. no new valves, no cracks, springs all shimmed 0.020. compression 190 psi +- 2 psi.
350K Front/rear crank seals leaking, clutch slave died. Engine pulled. Compression at 188 psi. Cyls showing crosshatch still. Main bearings .001 out of spec, crank journals all in STD specs. STD mains and rods installed, new oil pump installed. New timing gears installed, no defects in old gears.
This is a work truck, frequently towing either a 4T bumper pull trailer or a 10T gooseneck flatbed, several X country trips, max X country weigh slip, 24,500 pounds. Unladen weight, 5800 pounds. Winter usage, 8' snowplow and 8' slide in sand spreader, full loaded sander, 6600#.
Estimated retirement mileage, 480-500k
-Jason
-Jason
#180
I've got a '95 F-150 with only 42k on it. Use it mainly to pull a #5800 trailer which it does with ease ;-) The only reason I bought the truck in 95 with that engine was because my brother had one. He never took care of the engine but it still ran like a champ. (I take care of mine though!!)
