Help....starter problems....?
Old Dec 29, 2003 | 04:46 PM
steve81's Avatar
steve81
When I try to start my truck, it won't start and it sounds like the starter is just spining. Is it the starter itself or could it be something else like the solenoid?
Any help would be appreciated,
Steve
Old Dec 29, 2003 | 04:49 PM
luckild's Avatar
luckild
The bendix is shot. R/R the starter and that should deal with it. Also check ring gear when you take the starter out for missing teeth. Good luck.
Old Dec 29, 2003 | 05:01 PM
steve81's Avatar
steve81
What is the bendix? What do you mean by "R/R the starter..."? Sorry, kinda new at this.
Steve
Old Dec 29, 2003 | 05:05 PM
Franklin2's Avatar
Franklin2
The bendix is the gear assembly on the end of the starter. It has a one-way clutch/bearing, so the starter can drive the flywheel, but the flywheel/engine can't drive the starter. If this clutch goes bad, it can just sit there and spin. Cross your fingers and hope you don't have any teeth missing on the flywheel.
R/R means remove and replace.
Old Dec 29, 2003 | 05:08 PM
luckild's Avatar
luckild
In the starter is a one way bearing to allow the starter motor gear to drive the flywheel. The bearing is no good. R/R means to remove and replace the item.
Old Dec 29, 2003 | 05:24 PM
steve81's Avatar
steve81
Crap....this just occured to me: when I bought the truck, the flywheel had to be replaced because of this similar problem. What could be causing this to happen?
Old Dec 29, 2003 | 09:45 PM
rander101's Avatar
rander101
I don't see where you specified the year, model and engine in your truck but, in the 351W and, I think 302, manual transmissions and automatics required different starters and they were not interchangable. If you have the wrong starter in there that could be the cause of your problem.
RussA
85 F250 351W
Old Dec 30, 2003 | 04:28 PM
steve81's Avatar
steve81
I haven't had a chance to get up under the truck yet, but do you know what size socket I'll need to get on the bolts holding the starter? Is it as simple as removing the old starter and installing the new one, or are there other steps I need to be aware of? (This is the first time I've done any work like this on a truck.)
Steve
Old Dec 30, 2003 | 04:29 PM
steve81's Avatar
steve81
It's an 81 F-250, but somebody has put a 460 engine in it. It's a 4 speed manual.
