Will a 99 Engine fit in a 97 truck??
Same engine, diff. injectors and computer programming, turbo set-up may be different, too. I'd just do a hardware swap, then bolt all your old stuff back on, use your old injectors or get a custom chip to run the split shot injectors.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
I would keep the split shot inj. They make more power, and better fuel econ, JMO. You will need to swap the IDM,CPU anyway. Use the torque conv. from the 99, 4R100 it is a better T/C then the OEM E4OD T/C in the 97. If you can get the 99 trans too. Modify the core support for the intercooler hoses. Firewall clearance will be a problem with the turbo & exhaust, it is a different turbo and mount compared to the 97. Whats wrong with the 97? Is it up for sale?
