error code activation
Old Dec 12, 2003 | 03:24 PM
scottskingdom's Avatar
scottskingdom
error code activation- tranny guru needed
I am working on a 4r70w in a 99 expedition xlt 4.6L 4x4. when upshifting from 2-3 and 3-4 car registers error code.none at upshift 1-2 at any rpm. error code at 2-3 upshift only at 3000+ rpm.error code at 3-4 upshift at 2000+.
no gears slip. tranny performs fine- at 66000 miles. fluid is red with brown but NO suspended particles. overdrive/ error code light (on gear selector stick) always resets fine (ignition off) and when flashing still has overdrive gear. No tranny driving performance issues Ive noticed (accept maybe downshifts a little bit firmer then before- but this may be my imagination!)
cant get code read until Monday. what would most likely be fault with the above syptoms :
1) 3rd gear solenoid / or other solenoid?
2) piston/spring in valve body/ power valve spring?
3) speed sensor?
4) fluid/filter change?
or if I missed it- whats the most COMMON thing it could be with these symptoms that I dont have listed???????
THANKS!!!
thanks, tryin to be prepared for what to expect. plan on changing fluid and any bad parts myself , since tranny seems easily accessable compared to other trannys I've worked on.
Old Dec 13, 2003 | 03:18 PM
scottskingdom
With the symptoms listed above a transmission company says Ill probably get a torque converter slip code?
so this could mean the pwm solenoid or the tcc solenoid or?
Thanks for any ideas.
fourty03
Dec 4, 2014 01:12 PM
Steve Spano
Mar 5, 2013 04:56 AM
lincolnboy73
13
Aug 17, 2012 04:41 PM
scottskingdom
Dec 19, 2003 10:30 AM
scottskingdom
Dec 13, 2003 03:19 PM
