Sponsored by: Real Truck
Multiple control modual and sensor errors
Old Sep 1, 2025 | 01:27 PM
Cicchetti's Avatar
Cicchetti
2nd Gear
Hi new to ford forum so this question or issue has probably been addressed. Any help would be greatly appreciated. I have a 2008 f250 super duty 5.7 gas
im coming up with these codes
u011-20 po451-ff po 710-ff po713-ff p1876 p1832
b1318 u2023-20
and then under dtc I’m getting these
1.4x4m (control module)
3.pcm (power control module)
5.gem/sjb (generic electronic module / smart junction box)
ic (instrument cluster)
4.acm (audio control module)
6.tbc (trailer break control module)
everything Seems to be working normally except radio and sometimes transmission seems to shift a bit hard. (Rarely). Cannot clear pcm and 4x4 codes.
I did change transmission and transfer case fluids. No metal shavings inside. 190k miles
truck does ride a bit rough in general. Battery voltage is 12.47. I thought hopefully someone can zero in in on what’s going on before I start buying module after module sensor after sensor. Thanks for any inpu
Old Sep 1, 2025 | 01:30 PM
Cicchetti's Avatar
Cicchetti
2nd Gear
b1318 u2023-20
truck does ride a bit rough in general. I thought hopefully someone can zero in in on what’s going on before I start buying module after module sensor after sensor. Thanks for any inpu
btw the po451 was disconnected
BTroll
Computer Chips & Tuners
Sep 10, 2024 10:18 PM
YooperUno
1983 - 2012 Ranger & B-Series
Nov 10, 2022 12:58 PM
4wd6.7L
Aug 17, 2022 11:31 PM
b1ghwx
Jul 28, 2019 10:51 AM
