New SD Owner w/ questions
Hi, I bought a 2003 f250 cc shortbox 4x4, it has the 5.4 engine and I am wondering where are the sparkplugs? sounds crazy but I don't see them. I am also wondering how the limited slip rearend works, also when I turn the **** on the dash to 4wd, is it "true 4wd" or does just one tire up front grab, I normaly leave the hubs in the auto position if this any help.
Under the yellow things on the top of the heads. The plugs use a coil-on-plug system so traditional wires are not present
Search the threads or go to www.howstuffworks.com for a neat explaination with images!
Again, this is has been covered a few times. I say that simply to help you get a larger understanding of it. reading many replies helps. The "simple" answer is that the front diff is an open diff so only one wheels "pulls".
Welcome to FTE!!
Welcome to FTE!!
They're under the coils.
Like crap. I think it was a waste of money in mine. Others have had limited success with theirs.
>any help.
It does not have "lockers" in either dif, but does work like anybody elses 4x4 (stock) It is NOT "all wheel drive". Really its usually just 2 wheels (one front and one rear) doing the work under limited traction conditions. Leaving the hubs in "auto" is S.O.P.. You can manually lock them if you wish (or if the "autos" fail).
Welcome to the site
>any help.
Welcome to the site
51chris
10-14-2011 12:32 AM
dmason
08-26-2006 06:03 AM
026TB4U
1997-2006 Expedition & Navigator
05-13-2005 11:03 AM
