cold trans problem
Old Nov 27, 2003 | 06:24 PM
greeneye150's Avatar
greeneye150
cold trans problem
hi guys,
since i had my AOD trans rebuilt in my 90 cougar it has been fine. but now with colder weather, when car is still cold, i get a slight slippage in changing from first to second, also the first few stop signs or red lights i stop at, the trans seems to disengage for a second or two. when car gets hot, i have no problems at all.
what could this be?
I barely get a fluid reading when cold, but hot it shows in operating range.
should i add fluid to he trans while cold so i get a reading???
any input is appreciated
Old Nov 28, 2003 | 01:08 AM
wolfen's Avatar
wolfen
Hi greeneye150,
Check to see if the proper trany fluid is being used.
May also need a band readjustment or just may be new part stiffness.
Old Nov 29, 2003 | 12:22 PM
Talyn's Avatar
Talyn
I'm with wolfen on that.
Might be wrong fluid.
There are a few types of tranny fluid.
and you are supposto check your fluid at operateing tempature.
But it seems od to get nothing when you check while cold.
tgspencer
Aug 9, 2015 06:25 PM
AggieOutlaw
May 19, 2015 02:26 PM
rlebar
Feb 13, 2014 05:27 PM
Coolball
Oct 4, 2012 08:49 AM
tgspencer
Oct 25, 2004 12:19 AM
