2005 e250 service
Old 05-24-2024, 06:20 PM
djjdog97502's Avatar
djjdog97502
djjdog97502 is offline
3rd Gear
2005 e250 service
i have a 2005 e 250 service van, it has manual door locks and manual windows. i have driven it for a while, then it started acting up. i have changed, fuel pump 2x , fuel module, filter, tps. i have been trying to figure out why it dies. start it up, runs for a couple of min, dies out. try to crank it without cycling ignition. it wont start. but if you cycle ignition it will start right up. run for a few min, then die again. i had played with the throttle module and made it mad but it kept running. then i tried to do the relearn for throttle and it was back to dying. i am just not sure what else it could be. i guess the other thing, it doesnt throw dtc. only if i do something to test. otherwise it has no code.... anyone got any help?
Old 05-24-2024, 06:25 PM
tabijan's Avatar
tabijan
tabijan is offline
Which engine?
Do you have a scanner that reads fuel pressure? Did you replace the fuel pump because of this behavior or something else?
Sixto
07 E350 5.4 198K miles
Old 05-25-2024, 05:45 AM
manicmechanic007's Avatar
manicmechanic007
manicmechanic007 is online now
Received 1,154 Likes on 1,050 Posts
I sure would visually inspect the fuel pump driver module
The ground at its base may have deteriorated and the module is failing as a result?
Also, while checking the fuel pressure PID, you can disconnect the fuel pressure transducer and that will force the pump to a 100 percent duty cycle
See if it runs with that transducer disconnected, see what the scan tool says the pressure is, and go from there
Good luck
Have fun
The following users liked this post:
JWA
Old 05-25-2024, 09:07 AM
djjdog97502
3rd Gear
Originally Posted by tabijan
Which engine?
Sixto
first time i replaced was because of this issue, second time was because the first pump failed. fpr shows 50-60, drops to 35 when i turn off vehicle. no indicator of fuel drop out during the event.
Old 05-26-2024, 08:19 PM
djjdog97502
3rd Gear
Good luck
Have fun
checked will recheck ground. dont know where transducer is but would try that to see if makes changes
Old 05-26-2024, 11:41 PM
manicmechanic007
The fuel pressure transducer is on the fuel rail that all the injectors plug into
Well, the body of those FPDMs corrode and the whole thing starts to fall apart
If yours is intact, it is most likely okay
There are codes for it failing as well
Tkess999
2004 - 2008 F150
09-06-2023 04:40 PM
quesey
2004 - 2008 F150
09-20-2018 05:37 PM
Jebs
Modular V8 (4.6L, 5.4L)
01-16-2015 06:28 AM
rettus72
2004 - 2008 F150
10-15-2012 05:54 PM
FarmForward
04-22-2006 03:06 AM
Quick Reply: 2005 e250 service
