Why not just take the panel off yourself and peel the plastic cover and look yourself. The window people have to do this to replace it why not look when they have it apart?
Not ripping the door apart, also the trucks under warranty. I'm not replacing the window until the dealership looks at it. Hopefully something obvious shows up than.
It's not open heart surgery, 15-20 minutes and a quick look.
That side glass gets removed and replaced without door panel removal, but, if there is suspicion that something inside the door is causing the crack, then yeah, door panel will come off.
