Power window parts
Wanted
Miscellaneous
  • Expired
  • Price
    Any Price
    • Trade
  • Location Fairhope, AL, 36532, USA
  • Condition New or Used
  • Compatibility
Make Model Year
Ford 3/4 Ton Pickup 1999 - 2004
Description:
I need a driver side switch panel that controls the windows and door lock and I need the wiring harness that feeds that switch panel. I'm converting an XL truck to have power windows and door locks. So it also needs to only have front powered windows. The switch panel from a 4 door truck would have to many switches. Thanks!
Old Jul 4, 2024 | 01:38 PM
runningman777's Avatar
runningman777
Tristian,
I don't know if you have this figured out yet, but you will pretty much need a complete XLT or Lariat wiring harness plus the fuse box AND the GEM module.
I would look for a wrecked donor truck and gut it...
The harness that runs to the door does unplug up above the throttle, but I don't know if the rest of the wiring between the fuse box and the doors are are included in the XL trucks.
When I converted my XL to a Lariat, I swapped out the entire harness and dash. Actually, I swapped out everything from the wrecked donor truck except for the sheet metal and glass.
Old Jul 8, 2024 | 07:41 AM
twinzilla's Avatar
twinzilla
I'm about to part an 01 regular cab F350 Powerstroke 4X4 XLT with power windows. PM me if still looking for the power window parts, the truck is still complete so I should have whatever you need
