2013 F150 7-pin fuses
Old 05-07-2023, 06:28 PM
catahoula lou's Avatar
catahoula lou
catahoula lou is offline
4wd Low
I used my multimeter to determine that no voltage is going to the 12+/charging pin on my factory-installed 7-pin RV bumper-mounted connector. I downloaded/printed the layouts and fuse numbers/functions on both my passenger compartment fuse box and engine compartment fuse box. Quite a lot of fuses...
Before I start pulling/inspecting assumed blown fuses that might go to this particular pin, which fuse(s) correspond(s) with this pin?
Thanks,
Thom
Old 05-07-2023, 08:03 PM
RLXXI's Avatar
RLXXI
RLXXI is offline
Mr. Electric
Received 1,390 Likes on 1,100 Posts
Thanks,
Thom
@catahoula lou
Check the battery junction box under the hood for the trailer tow battery charge relay and F21. My truck came with both of those items in a bag in the glovebox when I bought it new. If you are not the original owner the previous owner may have never installed them.
The following users liked this post:
Old 05-08-2023, 09:20 PM
tiredmec's Avatar
tiredmec
tiredmec is offline
well first thing to look at is the 7 pin socket. They separate into two pieces. Mine had the green starting in the terminals just had to clean both pieces. I went ahead and changed the plug. The o- ring between the half's needs jelly to help put back together. Bet its this area.
Old 05-12-2023, 02:36 PM
catahoula lou
4wd Low
Thanks for both suggestions. Been very busy but plan to try both next week and then get back to you. I'm the original owner.
Thom
speakerfritz
2017+ Super Duty
11-23-2021 12:51 PM
CSANDERLIN
03-24-2018 06:24 PM
Dan Glover
Modular V8 (4.6L, 5.4L)
07-22-2016 01:38 PM
dudewayne
1999 to 2016 Super Duty
01-08-2016 05:31 PM
89f150
05-02-2001 12:59 PM
Quick Reply: 2013 F150 7-pin fuses
