I have a set of 20x11 10 in 225mm wheels that are custom made to run SRW on a F450/550. They have old 15.5/80R20 military tires mounted on them that have good tread, but cracks on the sidewalls. These came off of 2006 F550 axles, the track width front to back is the same running these. Also can rotate tires, just flip the wheel front to back.
Hi how's it going. Do You still have the 550 super single wheels ? Do you know the manufacturer of them? Im new to this site and not sure if ill get notifications or not. If it's easier for you. You can text me 403-710-4150. Thanks a bunch.
Reason: Made a mistake
Hi, I made them myself. Yes they make for equal track width. BUT come to find out, I used Ag rim shells, so a LT 20” tire will not bead up on them. Ag tires and some truck tires only. Also, the tires are now dismounted from the rims.
