Lighting issues
Old Dec 27, 2022 | 08:46 AM
21172's Avatar
21172
4wd Low
Lighting issues
Hi I have an 02 f350 7.3 srwthis truck has been used and abused. It's currently a plow truck that the bed rotted off and they put a 2x6 flatbed on and has a salter mounted on it.The problems he's having is with All of the lights. I got everything working in the front with the truck and the plow lights. Corroded sockets got replaced with new. Grounds that were bad got repaired, and others were replaced entirely.Now what were dealing with is the rear. Only have parking lights on the right side and absolutely nothing on the driver side.and replacing existing lights with 3 wire light.Can anyone tell me what color wires are for what?On the driver side I have a black, brown, red, white, and green with an orange tracer. Only have power on one of them. When checking with a test light with the blinker on, none of them have power.. same with brake, nobody's home.Help!
Old Dec 27, 2022 | 09:52 AM
Franklin2's Avatar
Franklin2
I recommend you replace a lot of wiring with a trailer ribbon wire. The original Ford color for the taillights and license light is Brown. This is a simple one wire circuit and should be spliced and lead to each light and the license light.
The original Ford wire for the left turn/stop was lightgreen with a orange stripe. The original Ford wire the right turn/stop was orange/lightblue. The original reverse light wire was black/pink.
A lot of the wire colors you listed do not seem too be original factory wire colors. I would trace the wiring to the front and try to find where they changed the colors of the wires, that might be the problem spot.
I will attach a diagram of the rear lights.
File Type: pdf
Old Dec 28, 2022 | 10:28 PM
21172's Avatar
21172
4wd Low
Thank you so much. Guess we got a lot more work to do. Don't know when we'll get back to that truck but this will help. Thanks again
Old Dec 30, 2022 | 03:17 PM
21172's Avatar
21172
4wd Low
Ok so I've located the trucks original wires and colors.
Yes brown is parking lights
Green with orange tracer is left turn
Orange with blue tracer is right turn
Black with pink tracer is reverse.
There is a Green wire separate, that is the brake.
How do I wire the new lights so the brake light works??
The new lights are only 3 wire.
Green= parking lights
Black= reverse
Red= stop and turn
The light gets ground from a stud.
When I try the GREEN brake light from the truck to either the red or green on the new light I lose the turn signals.
What am I doing wrong?
What is the proper procedure?
Old Dec 30, 2022 | 04:06 PM
Franklin2's Avatar
Franklin2
Forget the brake only wire. When you are testing your turn wires, have someone step on the brake. The turn wires should both turn on a solid 12v if the turnsignal switch is in the middle. If you move the turnsignal switch right or left, while still stepping on the brake pedal, either light should start blinking while the other light still stays on solid. All this magic is done in the turnsignal switch. The only other way to do it is European style, with rear amber turns and separate rear red brakes. Your truck is not set up for that though.
So to review, you should have one wire (brown) that is the tailight wire. It goes to both lights and comes on with the headlights. Make sure you use the less bright filament in the bulb for this.
The other wire you are calling the turn wire, IS the brake wire also.
And if you are using reverse lights, that is also a simple one wire circuit that goes to both sides like the taillight wires.
Old Dec 30, 2022 | 04:48 PM
21172's Avatar
21172
4wd Low
Ok. I get what you are saying 100%
what I'm saying is I have no brake lights at all.
Park and turn work. But no brake lights.
Old Dec 30, 2022 | 06:01 PM
Franklin2's Avatar
Franklin2
You need to check the brake switch under the dash. It used to be a lightgreen wire in the old days. The rear wiring has the same colors as the older trucks, so it's probably the same. The wire entering the brake switch should be hot all the time. Hopefully you just have a fuse blown. The other side of the switch should have power when you press the pedal. This wire leads up in the steering column to the turnsignal switch where the magic occurs. The turnsignal switch mixes the brake pedal signal and the signal from the turnsignal flasher together and directs the proper signal to the proper light in the rear, depending on where you have the turn lever.
Old Dec 30, 2022 | 06:48 PM
Franklin2's Avatar
Franklin2
Look at fuse #18, #34, and #27 in the underdash fuse box. The wires to the brake switch are lightgreen with a red stripe.
Old Dec 30, 2022 | 06:58 PM
21172's Avatar
21172
4wd Low
Ok I will look into that. I've verified all the fuses in the block are good. And like I said I only have brake signal on that one green wire.
Neither turn signal wire will give me a brake at this point
Old Dec 31, 2022 | 06:49 AM
projectSHO89's Avatar
projectSHO89
Sounds like a defective MFS. Pretty common failure.
Old Jan 2, 2023 | 02:56 PM
21172's Avatar
21172
4wd Low
You guys are top notch!
Someone had cut the green wire at the brake switch to wire something else and just left it hanging out.
All better now thanks to your help!
stuckstudent
30
Jun 2, 2023 07:36 PM
21172
General Automotive Discussion
Dec 30, 2022 03:18 PM
abe
Feb 26, 2013 05:31 AM
gravydude
Oct 29, 2008 09:15 AM
logan_85
Electrical Systems/Wiring
Jul 17, 2001 10:30 AM
