Sponsored by: Real Truck
Need help
Old Dec 21, 2022 | 08:46 PM
J. J's Avatar
J. J
2nd Gear
Need help
I have a 2004 f350 dually with no rear running lights. I have turn signals and brake lights. I put a new headlight switch checked all my fuses everything looks good but I still can't figure out the problem
Old Dec 21, 2022 | 09:58 PM
jenkinsd's Avatar
jenkinsd
4wd Low
There are 2 relays in Aux. Relay Box #2, There is a Resistor comes directly from Fuse 2.14 15 Amp. Location Aux. relay box #2 engine compartment LH side fender well back by firewall, Resistor engine compartment LH side next to ground fender well towards front of vehicle. Five pin relays relay #1 pin 4 WH/BK, relay #2 pin 87A RD/YE. Resistor connector C196 pin #1 OG/LG goes to relay #2.
Old Dec 22, 2022 | 04:21 PM
J. J's Avatar
J. J
2nd Gear
I swapped out both of those relays and till no luck
Old Dec 22, 2022 | 09:25 PM
jenkinsd's Avatar
jenkinsd
4wd Low
ARE you California emissions? 6.0l diesel? Check fuse 2.14 15 amp. Check circuits through connectors starting at main fuse box ye/bk wire, through DRL resistor OG/LG wire, through DRL relay 2 and 1. You might not be hot directly out of main fuse box. Is resistor ok, check ground. Trace your harness. DRL OG/LG wire in your pig tail, BK in pig tail is ground.
Thor racing
Jun 25, 2017 03:10 AM
GDK388
Dec 11, 2014 09:31 AM
Robbig34
Apr 28, 2014 03:43 PM
fixitman1310
May 1, 2011 08:46 PM
