Quick interior question
Old Dec 20, 2022 | 09:03 PM
Branden Heine's Avatar
Branden Heine
Did the 1980-1986 ford trucks come with a carpet panel on the cab wall behind the seat? And would one from a 87 on ford truck fit the earlier trucks?
Old Dec 21, 2022 | 06:09 AM
Franklin2's Avatar
Franklin2
I had a pretty fancy 1980 f150 and it did not have one. But that doesn't mean it didn't come out later. My 1989 does have one, I see no reason why a later model would not fit in a older truck.
Old Dec 21, 2022 | 08:59 AM
White Lightnin''s Avatar
White Lightnin'
They didn't change the cabs that much from 1980 through 1996 so it should fit fine.
Old Dec 21, 2022 | 10:18 AM
Old Hickory's Avatar
Old Hickory
I have a 1987 back carple in my 1981 and it fits fine.
Old Dec 21, 2022 | 06:24 PM
Branden Heine
Seat belts
I had a guy offer to sell me the interior cab corner plastic trim but I’m absolutely lost on how the seat belts bolt in because my retractor is at the top while these are at the bottom and my current seat belts don’t have a spot to bolt through the hole at the top of the trim
Old Dec 21, 2022 | 07:14 PM
Franklin2's Avatar
Franklin2
When swapping parts around, you have to pick the place where you are going to stop with the new and go back to the old. If the plastic you want to use requires a different belt setup, then you need to get the newer belt setup along with the plastic. Do you have the proper bracket to bolt the different belt system in place? I don't know, but if you need to fabricate a bracket, that might the place where you finally stop and go back to the old
Old Dec 21, 2022 | 07:53 PM
Branden Heine
if I have to buy new seat belts I will I just can’t find pictures of trucks with that certain trim peice
Old Dec 22, 2022 | 06:41 AM
Franklin2's Avatar
Franklin2
I picked Kansas and pretended I was looking for a 1990 cab for a f150, and picked I wanted one with a headliner. Here's what came up. They may have more trucks around with the parts you need or they may sell you the trim out of these cabs. You can also try different years, the site is this one www.car-part.com
1991
Cab Shell Assembly
Ford Truck F350 w/cab lghts,no rust,RED,2 DR, XLT,AT 000 A
0 104891 $550
actual Payless Auto USA-KS(Soldier) Request_Quote 888-899-0907 / 785-924-3600 Request_Insurance_Quote
929 1990
Cab Shell Assembly
Ford Truck F150 Regular Cab headliner w/o transmission opening GRAY EXT 2DR XLT 4X4 Prt: CAB 000 A
0 00000407 $200
actual Emporia Auto Recycling USA-KS(Emporia) Request_Quote 620-208-7875 Request_Insurance_Quote
Old Dec 22, 2022 | 12:51 PM
Branden Heine
I might be wrong in this but it seems the corner trim with the retractor at the bottom was for a truck with bucket seats? While the one with retractor at the top was for bench seat trucks?
Old Dec 22, 2022 | 04:14 PM
Franklin2's Avatar
Franklin2
Not sure about that. I will warn you though, when you start messing with the retractor, it has to be positioned exactly how the factory had it. If you mount it different, you will never be able to use the seat belt, the retractor will be locked.
If you notice what you have now, once you fasten the belt, you can still pull the belt out and sometimes in, even though you are latched in. If you hit the brakes hard and try to pull the belt out at the same time, you will find it locks up. This is because there is a pendulum inside the retractor and lets it run free unless the pendulum swings. If you mount the retractor wrong, and the pendulum is to the side all the time, the retractor will lock up and not work.
Old Dec 22, 2022 | 04:40 PM
Branden Heine
Then I’m wondering why some retractors were at the bottom and some at the top
earl82461
Transit Connect
Feb 1, 2017 06:43 AM
boaterbob
Jan 15, 2011 01:15 PM
gohorses
2009 - 2014 F150
Dec 28, 2009 10:04 PM
JMS50F5COE
Large Truck
Jun 18, 2009 09:47 AM
Buckboard6-300
Feb 12, 2008 11:46 PM
