Flat Tailgate Insert
Old Nov 29, 2022 | 08:22 AM
rahulke's Avatar
rahulke
8th Gear
Good morning. I'd like to make my tailgate a little more useful by replacing the ridged interior insert with a smooth one. I'm looking at this one for my 2020 F-350: Mountain Hatch Tailgate Insert | Ford F350 (2017-2022) (truckbrigade.com). Do any of you have any experience with this or has anyone fabricated their own? I have a spray in bed liner so am wondering how difficult it will be to remove the old insert. Seems like it would be relatively easy to make one but I doubt I'd save much money by doing so. Any advice is appreciated.
Old Nov 30, 2022 | 04:59 AM
Baja Fog's Avatar
Baja Fog
Why would I pay so much for a plastic board? $291 for this one: https://realtruck.com/p/dee-zee-tail.../dez-dz284103/
How about we snag a half inch piece of plywood, cut and paint it? What am I missing?
I like this one and only $179, but I don't see my truck listed: https://danaport.com/products/access...tailgate-step/
Old Nov 30, 2022 | 06:16 AM
bigfish1688's Avatar
bigfish1688
I like the idea. I'm constantly using my tailgate as a workbench servicing chainsaws, etc. Flattening it out would make it a lot more useable. That Mountain Hatch one looks a lot like a sheet of 1/2" Starboard cut to fit. that stuff is VERY expensive but not too far from me there is a marine surplus that sells remnants relatively cheap. For anyone that has never worked with Starboard It can be cut, drilled and routed with common woodworking tools.
Old Nov 30, 2022 | 07:51 AM
#1bigmark's Avatar
#1bigmark
Temporarily Deactivated
Yeah it’s amazing how much people will spend on things.
if I wanted a flat surface to work on with my tailgate I’d take the sheet of 3/4” black barn stall mat I keep in the bed of my truck and slide it back onto the tailgate. Now that wouldn’t work if a ton of stuff is in the bed but a guy could cut a section of that barn stall mat to fit the tailgate and use some self tapping screws at attach it to the tailgate.
a 4x6’ sheet is 39 bucks at any farm and fleet type store or tractor supply.
Old Nov 30, 2022 | 09:09 AM
ToMang07's Avatar
ToMang07
I have used my truck in many a ways, but I have never had an issue that made me think "Hey, I'll spend $300 to make that a little flatter..."
Old Nov 30, 2022 | 09:56 AM
34SF's Avatar
34SF
I could see using 1/2" HDPE as well. Easily worked with basic woodworking tools.
Old Nov 30, 2022 | 10:22 AM
TCNashville's Avatar
TCNashville
I have a BedRug tailgate cover and it works well as a work station. Just velcros on.
Old Nov 30, 2022 | 10:51 AM
jake415's Avatar
jake415
Anything smooth on a tailgate should require a "Slippery When Wet" sign....
With the possible exception of the horse stall mat. Anybody actually tried that and can share how slippery it is when wet ?
Old Nov 30, 2022 | 10:52 AM
chadstickpoindexter's Avatar
chadstickpoindexter
Same here. The BedRug is awesome!
Old Nov 30, 2022 | 11:09 AM
#1bigmark's Avatar
#1bigmark
One side is flat and the other has a pattern. They Will literally last longer than the truck. Certainly longer than a sheet of plywood and for the same price. This sheet weighs 97lbs so they are extremely dense and indestructible.
Old Nov 30, 2022 | 11:19 AM
smikesF350's Avatar
smikesF350
Another option would be to check out a couple custom countertop shops to see if the have some rems or drop off pieces of Corian or other types of materials. It's easy to cut and shape with simple woodworking tools.
Old Nov 30, 2022 | 11:22 AM
#1bigmark's Avatar
#1bigmark
To ice skate on? Not to mention if you have to crawl across the truck bed on your knees. Ouch. Nothing better than barn stall mat
Old Nov 30, 2022 | 11:30 AM
6.2caribou's Avatar
6.2caribou
I help a buddy that does solid surface countertops as a business. We usually make cutting boards out of the sink cutouts...it makes a good material for this. Shops will normally have scraps leftover, but realize that most sheets come in 30" widths, so it would take a 50"+ lengthwise "scrap" to cover a tailgate. With the way that Corian and Hi Macs prices have skyrocketed, that may be a tough find. And then there's the issue of the lack of UV protection, along with it being more brittle when cold and/or unsupported underneath.
Old Nov 30, 2022 | 11:50 AM
rahulke's Avatar
rahulke
8th Gear
Thanks for all the suggestions, much appreciated. I knew you guys would have good ideas. We use the tailgate when camping - for the grill, the Blackstone griddle, cleaning fish, cleaning game birds, or just setting down a cup of coffee or a beer. I'll probably go with either the horse stall mat or plywood. I had the BedRug in my F-150 but it did not get along well with fish hooks.
Old Nov 30, 2022 | 05:09 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
1/8" sheet of aluminum cut to fit would be nice....
