How this sound crank no start 6.4 only p0472
if you already try to help me but don’t want to help me more than that fine just looking for suggestion I replace hpfp gasket because fuse 72 kept blowing leaving me stranded
As I suggested in one of the other threads. You need to find someone that knows diesels and get them to look at it for you. We've pretty well exhausted our recommendations. Without being there and looking at things I can't help you anymore. You need to have a analyzer that can read sensors. You need to be able to read fuel pressure, temps, ipr, cps, crank voltage, crank speed, and other pids. Without that you are guessing and that doesn't work. I just went through this with a Cummins diesel in my motorhome. I had a analyzer that didn't show all codes and I almost replaced the whole fuel injection pump because analyzer didn't reveal a ecu issue. That would have been a $3500 mistake. In my case I purchased a Cummins Insite analyzer only to find issues that weren't fuel related. What I am getting at is you need accurate information and someone that knows how to analyze it. You have been down for quite some time. Time for a second set of eyes on it to figure your problem out.
hey here a quick updates I tear everything down twice to check for leaks both of banjo bolt on top of the hpfp was leaking i retighten them and im in the process of putting everything back .. do you think this is the reason why it wouldn’t start? I don’t think nothing serious is wrong with my truck when my truck died on me I had the code p0003 fuse 74 blown I replace the hpfp gasket now the issues gone with the fuse blowing and etc so it’s should start knowing everything is tighten no leaks
Did you check to be sure the copper washers were there and that's why it was leaking or were they just loose. FWIW, don't just tighten the banjo bolts. Go to the parts house and get new washers.
And yes, a fuel leak could stop it from starting but you should have seen that fuel on the ground under the truck.
yes I check they was there but I replace them with some new washer and tighten them even harder I connected the fuel system and then koeo and I checked for leaks …I have to replace the oil supply line that go into the turbo I’m having a hard time taking that’s supply line off but on the 19th I’m taking my truck to the shop after I get the oil supply line replaces any tips on getting that’s out… also my oil dipstick started to smell like diesel so I suspect that’s it’s was leaking from the banjo bolt onto the pump if it’s was the rail inlets or pump fitting it’s will leak from the back of the engine buts those banjo bolt wasn’t leaking bad but koeo I had seen bubbles going around the fitting as if it wasn’t over tight
