computer codes
Old Oct 17, 2021 | 11:53 AM
khaled Alharbi's Avatar
khaled Alharbi
8th Gear
computer codes
Hi, I checked the computer codes and these codes appeared
F-150 1993 5.0
(654) transmission selector not in PARK -
transmission
(452)vehicle speed sensor (VSS) problem
(634) Park/Neutral Position (PNP)
or Clutch Pedal Position
(CPP) circuit fault
Electronic shift transmission
- Manual Lever Position
(MLP) sensor out of range
in Park-Transmissions
Does the speed sensor(VSS) have anything to do with the hard shift?
How do I solve code 634
Old Oct 17, 2021 | 11:57 AM
SFaulken's Avatar
SFaulken
I have no idea exactly what you're working on, but if it's an electronically controlled transmission (AOD-E/4R70W or E4OD/4R100) the VSS signal is needed by the transmission, as an input, to determine shift points. But those codes are telling you what you need to know.
You've got a VSS issue that needs attention, and the MLPS needs adjustment, if not replacement.
Old Oct 17, 2021 | 11:59 AM
khaled Alharbi
8th Gear
How do I change the MLPS, where is it?
Old Oct 18, 2021 | 09:46 AM
Scndsin's Avatar
Scndsin
Before you start loading up the parts shotgun, inspect all trans wiring connectors & I'd open the computer & look for leaking capacitors.
Very doubtful your VSS & the MLPS just decided to go out at the same time.
Old Oct 18, 2021 | 11:31 AM
khaled Alharbi
8th Gear
Can you explain in a better way? I don't understand my English is not good What does shotgun mean??
Old Oct 18, 2021 | 11:38 AM
Scndsin's Avatar
Scndsin
Sorry, no problem. It means to throw parts at a problem without diagnosing. Inspect, clean if necessary & test first.
The connectors, their wires & pins at the transmission & the vss sensor on the rear are subject to abuse.
The capacitors in the computer are past their life expectancy & leak frequently & cause faulty codes.
This computer along with the PSOM behind the speedometer gave multiple random trans codes:
Old Oct 18, 2021 | 11:41 AM
khaled Alharbi
8th Gear
I checked the wires, but I don't see any cut wires. I think it needs cleaning, because it has oil on it or Dust
Old Oct 18, 2021 | 11:47 AM
Scndsin's Avatar
Scndsin
The design of the MLPS is problematic & was changed from the connector inserting vertically to horizontal (from the side) because of contamination.
The connector on the passenger side should be behind a metal shield, but frequently has strain & heat damage.
How hard of a life has the truck led?
Old Oct 18, 2021 | 11:50 AM
Scndsin's Avatar
Scndsin
As asked above, what trans?
Old Oct 18, 2021 | 11:51 AM
khaled Alharbi
8th Gear
I don't think the problem with mlps It's good to change gears, But the problem is in the kick or hard shift Is the problem with MLPS or VSS?
Old Oct 18, 2021 | 11:53 AM
khaled Alharbi
8th Gear
trans E
axle 19
what does it mean
Old Oct 18, 2021 | 12:21 PM
Scndsin's Avatar
Scndsin
You have the bigger, E4OD trans & 8.8 rear.
Old Oct 18, 2021 | 12:30 PM
khaled Alharbi
8th Gear
thanks . Which number do I put in PSOM?
Old Oct 18, 2021 | 12:38 PM
Scndsin's Avatar
Scndsin
Hard shifts are known as limp mode. The computer increases line pressure to make sure shifts happen & things get lubricated. With mine, they came & went for years.
Old Oct 18, 2021 | 12:40 PM
khaled Alharbi
8th Gear
Does he have a solution?
