Poping when decelerating
Old Jun 24, 2021 | 05:20 AM
Thurston Jamie's Avatar
Thurston Jamie
I have a 1964 F350 with a 292 Y block and a 600 CFM Holley Carb. On deceleration I get popping sound through the exhaust. I advanced the timing and it seemed to go away, however when I re-adjusted the idle on the carb the symptoms returned. Not as bad as before but a light popping on deceleration and slight hesitation when tramping the throttle.
All new plugs and wires, brand new exhaust professionally installed, patriot headers and cherry bomb pro mufflers. Distributor, and cab has been cleaned and inspected and all looks good.
Did a compression test and results were excellent, fuel pump is operating properly.
Old Jun 26, 2021 | 10:24 AM
HT32BSX115's Avatar
HT32BSX115
Howdy,
How many miles on the engine? Have you adjusted the valves?
Have you ever had the timing cover off to inspect the timing chain?
I would be wondering is the valves are mis-adjusted or maybe even sticking a little. or you have a severely worn timing chain.....
Do you have smoke on deceleration?
Cheers,
Rick
Croberts2
13
May 21, 2012 07:26 PM
mktsc
24
Mar 17, 2012 06:14 PM
Icicle
Nov 17, 2005 12:31 AM
55Bubba
Oct 15, 2004 07:09 AM
stevef100s
Apr 8, 2004 10:09 PM
