Abs
Sabrina Ragan , 05-15-2021 03:05 PM
I’m pull up to my job today I drive and 2000 f150 5.4 v8 triton 4 wheel drive 180,000 miles on it and notice the abs light is on and I turn off the truck and still here something like the engine so I wait a few start it up ans still doing it listen to the following I need help
If it is a 4x4 most times it is letting you know that the hub is bad or going bad or that anyone of the brakes front and rear needs cleaning.
Two-wheel drive models, let you know that the bearings or front hub are bad as well or that anyone of the brakes front and rear needs cleaning.
Or
That they have dirt, brake dust that needs to be cleaned off so that it can read the signal and set the brakes correctly.
Look and make sure that the electrical line coming out of the front hubs and if you have them on the back brakes that it is still plugged in or not broken.
Forgot to add that you can check the hubs by jacking up the front end and taking each wheel and wigging the tires up and down and back and forth. If the tires wigger up and down you have a bad bearing or a bad hub.
