Puzzled
Old Mar 13, 2021 | 01:42 PM
20excursion's Avatar
20excursion
Puzzled
What would cause my park sensors to turn off when I go into reserve without pressing the button
Old Mar 13, 2021 | 06:36 PM
2002Ex's Avatar
2002Ex
Here's a diagram:
Here's a page with someone else's solution for that problem:
https://www.blueovaltrucks.com/tech-...ensing-system/
Good luck!
Old Mar 13, 2021 | 09:20 PM
carbon coupe's Avatar
carbon coupe
For mine, it was the speaker. Replaced it and good to go.
Block the tires, turn the key on, put it in reverse and put your ear at each sensor. If they are all clicking, it's the speaker.
Old Mar 14, 2021 | 06:32 PM
20excursion
Can one sensor be replaced at a time or do all have to be changed if one is bad
Old Mar 14, 2021 | 06:38 PM
carbon coupe
One at a time is fine. If you have one not clicking, check the connector and wiring first. Or, move another sensor that works too that position to check.
Sep 20, 2019 09:43 AM
78Hayride
Apr 7, 2019 09:43 PM
1986F150six
Mar 13, 2019 02:20 PM
WhatsAChevy?
1947 and Older Ford Trucks
Oct 3, 2017 08:23 PM
Dobies4life
Mar 10, 2014 10:39 PM
