engine swap
Old Jan 6, 2021 | 09:39 PM
TOM B1's Avatar
TOM B1
engine swap
I have a 74 hi-boy 4x4 that I am doing a restmod. It has a 360 or a 390 engine with a manual trany and devorsed transfer case.
I would like to bolt up a modern engine to it, what are my options. I need some power for towing my trailer plus better fuel mileage than the 8mpg that it now gets.
Old Jan 6, 2021 | 11:52 PM
85e150's Avatar
85e150
How much do you want to spend?
Easy? Cheap? Already supported? Billions served? Hundreds if not thousands of swaps already done? .....wait for it...... LS swap, bring a transmission along with it.
Like complexity? Coyote swap.
Got time, like to check for updates? New 7.3 gas swap. (No controllers yet)
Cummins oil burner?
Or build the FE into a 445 CI roller motor with EFI and a 5 or 6 speed trans, MT or AT.
So, how much are you wanting to spend and how much of this can you do yourself?
Old Jan 7, 2021 | 12:51 AM
Christmas's Avatar
Christmas
Well said! It all comes down to the wallet.
Old Jan 7, 2021 | 05:31 AM
User 71024's Avatar
User 71024
And your talent , one , the other or both.
What does the truck do normally, could be a new set of gears would help your mileage a lot.
Eric
Old Jan 7, 2021 | 03:08 PM
65f100_352's Avatar
65f100_352
I haven't done one, but what exactly makes the coyote complex to swap? It can be easily made into a standalone setup as the other modern motors
Old Jan 7, 2021 | 08:07 PM
440 sixpack's Avatar
440 sixpack
with the divorced T case it's not hard to put almost anything practical in front of it. but why, the FE is a great engine.
Old Jan 8, 2021 | 11:19 AM
meangreen92's Avatar
meangreen92
I'd probably just do a SBF 302 or 351W, since they're cheap, relatively plentiful, and can probably be made to fit properly, using all OEM mounting parts.
I'd probably go for the new 7.3 Godilla OHV engine over the OHCs Coyote, but a few years from now, when they're less uncommon and expensive.
LS? I would never do that, (except to an old Chevy) but a fellow on here named JacobJ, I think, has I think a stock 5.3 in his Highboy, and loves it. I guess I could settle for some aftermarket LS heads on a SBF or even on a 351M or 400, but that would require a custom intake manifold.
I've never had an FE engine. The first car I rode in and the first truck I ever drove both had FEs, but I think I would tend to shy away from having one which I was going to have to work on. I think they're pretty heavy too. But I'd readily own one if it was in a vehicle which was all finished up with nothing left to do but drive it.
Old Jan 8, 2021 | 07:18 PM
650's Avatar
650
Just 12v Cummins swap it.
If a 5 speed overdrive would make you feel good, a NV4500 will bolt in nicely with an adapter and trans crossmember modification. Thats what I did with my 390 until I decided I was still not satisfied.
Old Jan 8, 2021 | 07:46 PM
SDDL-UP's Avatar
SDDL-UP
I'd keep the FE honestly. It's the engine family that won Le Mans four years in a row - overall wins too, not class wins like today.
Get some modern aluminum heads and intake manifold, decent camshaft, and up the cubic inches - no reason the FE can't do anything you want. I'd keep it because it's the original engine type and a very capable platform. Keep it, but at 390 cubes or better.
Old Jan 8, 2021 | 08:27 PM
TOM B1's Avatar
TOM B1
Thank you all for the idea,s. I was wishing for a bellhousing swap and keep the trany but thats not happening I guess.
A friend reminded me of the 72 F100 360 I had till 1990. I made a turbo exhaust manifold with a crossover tube, back then
the choice of turbos was slim, I used a truck T04 but it was to big, I think I still have the manifolds somewhere, I will have to look,
Today turbos are everywhere, so I might just rebuild the 360 and add good heads, turbo it and use a Holley sniper Efi.
Old Jan 8, 2021 | 10:17 PM
buckin69bronco's Avatar
buckin69bronco
One way to do this is to just go find something that has what you want and make it work. In reality it doesn’t matter if it’s a Ford/Dodge/Chevy or what ever, they all take about the same amount of work (well diesel might be a bit more). A 90’s 351w or 460 would be a good swap but it’s an outdated motor/efi system and the effort to swap one of those is just as much as swapping something from a newer truck.
If you are a Ford purest then a coyote or 6.2 raptor motor would be sweet but $$$
Honestly an LS swap is probably the least expensive and best supported swap.
Have you considered just bolting on fuel injection to your FE?
Old Jan 8, 2021 | 10:36 PM
SDDL-UP's Avatar
SDDL-UP
Aaaaaa.... yeah! I'd still add some cubes, but yeah!!! LOL! A turbocharged, fuel injected 390, 428, or larger FE! 500HP easy, 600HP no problem, 700HP still not breaking a sweat! Opportunity for a really cool build here.
Old Jan 10, 2021 | 06:34 PM
TOM B1's Avatar
TOM B1
I have a brand new, still in the box Holley Sniper EFI kit that I bought when Holley had the Xmas sale, saved over 200 dollars. I have to
find out if I can blow through that thing.
Old Jan 11, 2021 | 02:55 PM
Jetfixer-6's Avatar
Jetfixer-6
As a purist I would put a Ford in a Ford, so if you are doing a restomod as you say and you are and you will be doing some towing, then I would say get the 7.3 Godzilla, or if you aren't towing big loads then wait for the 6.8 pushrod rumored to be coming in 2022 to the Mustang and F150. ( https://www.motorauthority.com/news/...tang-and-f-150 ) No matter what you throw at a 390 to make it faster, tow more, or to try to see 12 MPG, it isn't a "Restomod" The 7.3 is a better choice than the Coyote for towing as the torque starts to hit at 1500RPM whereas the Coyote gets it's torque much later in the rev's.
Old Jan 12, 2021 | 11:13 AM
TheMonson's Avatar
TheMonson
I haven't done one either, but guessing the hard part is the rest of the drivetrain behind the engine. Perhaps you can mate your existing with an adapter, but if I've learned anything just doing "bolt-on" stuff to my Mustang that has been anything but that this is surely a lot more difficult. One of those easier said than done type of situations.
