rear end swap
rear end swap
Hello everyone I am new to the Ford world... I have a 3/4 ton van 1985 and the rear gears are crap.. I want to change out the entire rear... What years van/ pickup will bolt right in??? what is compatible???
Can I even use the rear from an f-250?? is it the same?? any tips???
any help is greatly appreciated!!! Thanks
Jeb
Jeb
8 lugs is right.
I blew the axle on my 84 last year and tried using one from a 83 van. No way!
You are going to have to find a axle from a van to go to your van. I wound seriously think about changing out the gears instead.
P.S.: This probably should have went to Axle, Trans., Drivetrain forum. Just a thought.
Good Luck!!
Larry
1984 F250 4x4 w/460
1982 Mustang GT w/302
1993 Explorer 4x4 w/4.0L
Good Luck!!
Larry
1984 F250 4x4 w/460
