1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Bypass TPMS - 2015 F250 XL
Old 11-18-2020, 10:28 AM
Venturous's Avatar
Venturous
Venturous is offline
I am wondering if there is a fuse I can pull.... wire I can snip... component I can hit with a big azz hammer... that will bypass this lame OEM TPMS on my 2015 F250.
It keeps going off with perfect tire pressures and I have to jump through the reset hoops to clear it. I've had enough. I just want to completely disable this lame useless system. Any help appreciated.
Old 11-18-2020, 10:54 AM
David_h's Avatar
David_h
David_h is offline
I’m running without wheel sensors. On my 2008 instrument cluster I had the yellow warning light (annoying) and the green text message (ok by me) where other messages/info can be displayed. For a long time I had a black paper dot (Office Depot) pasted in front of the yellow light. Worked great. Later I had my cluster out for repair and at that time I had circuit medic disable the yellow light. I never found a fuse. Hope this helps.
Old 11-18-2020, 11:30 AM
92sho16's Avatar
92sho16
92sho16 is offline
If you have a ELM327 OBDII adapter you can download Forscan and turn of the TPMS system.
Old 11-18-2020, 02:49 PM
Venturous's Avatar
Venturous
Do you know if this will work with the Android lite version ot only the Windows version? Sounds like a handy setup to have.
Old 11-18-2020, 02:51 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Requires the PC.
Old 11-19-2020, 07:08 PM
gunit1400's Avatar
gunit1400
gunit1400 is offline
I used the OBDlink EX with my laptop using Forscan. Easy to turn off. Worth the $50 cost of the adapter.
Madmax1981
2017+ Super Duty
15
04-07-2022 08:27 AM
DSLTRK60
2017+ Super Duty
01-07-2018 10:49 PM
aphotic26
10-23-2015 03:46 PM
Quick Reply: Bypass TPMS - 2015 F250 XL
