87 F150 2WD 5 speed manual
For Sale1987 Ford F-150
Price
$10,000• OBO
- Location Long Beach, CA, 90813, USA
- Condition Used
- VIN 1FTDF15YOHPB40265
- Mileage 320,000
- Engine 6 cyl
- Drive Type 2WD
- Transmission Manual
- Vehicle Type Truck
- Exterior Color Red
Description:
87 F150 4.9l 2wd 5 speed manual transmission. It has a 95 zf5-42 in it now so the speedometer is not hooked up but it works. The 95 doesn't have a mechanical speedometer. I do have an 88 zf5-42 for it which has the mechanical speedometer but it needs a reverse gear and bearing. I also have an NP435 4 speed transmission (the orignal) for it that works perfectly. I did the swap for higher freeway speeds
It has a brand new Rough country 6" lift kit
35" Nitto grappler 11 tires with 16" wheels
all new bushings
new tie rods
New Ball joints
New drive shaft and u-joints
new paint job
All with about 200 miles on them
Fresh tune up about 8 months ago with new water pump, thermostat, IAC, TPS, MAP and fuel regulator.
Also has all new fuel lines and 3 new fuel pumps (1 in each tank and 1 on the frame) about 3 months old
New A/C
Brand new daul electric fans
And more that I am probably forgetting to list
