Why chevy always lead in HP?
#76
I can absolutley agree that Ford trucks, the Super Duty's specifically, are built tougher than GM HD trucks. The IFS simply doesn't hold up compared to the Solid axle on the Fords. I'm sad to see that Ford switched from leafs to coils on the 05's, but it's still better than IFS.
However, the topic of this thread was about power, not toughness. I think for a while Chevy had a pretty good power advantage. The 3V Mod's are better, and have closed the gap, if not taken the lead.
One point I will argue that others have stated as supposed fact is that Ford's are more efficient than Chevy and Dodge. This simply isn't the case. I own a V10 Super Duty and a Hemi Ram 1500. I know many others who own other Ford's, Chevy's, and Dodges, and I can say without a doubt the gas mileage between the three for similar motors is very close.
My neighbor has a 2004 F-150 5.4, and on the average, it gets nearly identical mileage to my wife's Hemi Ram. Ford certainly doesn't have a fuel mileage advantage like some here would like to believe.
#77
Yes they are all very close when it comes to mileage. They have always been really close, with Dodge ALWAYS being in last place. The new Fords do have the advantage currently, though. I can also say that Dodge's, on average, DO NOT get the mileagge their sticker claims, while Ford and Chevy get at least the EPA numbers unless you completely drive the he!! out of them.
#79
#80
This is my conclusion. When it comes to trucks Ford wins by a mile in torqe, reliablity, durabilty and towing capabilty. When it comes to cars chevy wins in my opion. Chevorlet makes car engines, high revving, short stroked, higher HP engines that have more mechanical issues then Ford. I am comparring the 60's and 70's Fords and Chevs new cars are stupid and irrleavant to me. Back then all the OEMs made decent vehciles now they are cheap and disposable.
Ford = Truck engines
Chevy = Car engines
Chevy = Car engines
#81
Thats a fair assesment. Fords always had great pride in there trucks. And as many as they sell every year. People love Ford trucks. Ford has the highest loyalty of the big 3. Ford trucks are on a roll this year selling 432,000 through June outselling GM by 11,000 trucks so far.. Fords goal is to sell one million trucks a year. There getting closer to that goal. Fords always had the better truck. Numbers prove it this year. With the new truck plant on line in Dearborn. Ford should have the manufacturing capacity to reach there goal.
#82
Originally Posted by Ev2Demon
I can absolutley agree that Ford trucks, the Super Duty's specifically, are built tougher than GM HD trucks. The IFS simply doesn't hold up compared to the Solid axle on the Fords. .
Solid axles are stronger - yes but there is absolutly no foundation to your claim of IFS failure in GM HD's. your blowing smoke.
Now is the the same 3/4 GM HD that has the highest GVRW ?
#83
Originally Posted by DMAX-HD
False - prove it!!!
I didn't see him say "The IFS fails all the time or even most of the time", I saw him say that it couldn't handle the same amount of abuse and you agreed....where's your beef?
#85
Originally Posted by 01F350V10
You said it yourself, the solid axle is stronger. Subject them both to an equal amount of abuse and stress and as you increase the stress and abuse the IFS will fail before the Solid Axle will.
#86
Evidently not. If none of the IFS setups had ever failed, then it would be overkill, but if you've not seen one fail, then you've not seen one in a serious tight spot. Some people need a truck to work with, not just one that's good enough to ride on the road. CV joints and other components = more components to fail, isn't that your reasoning as to why the Cummins is so great? Why the double standard? Simpler, stronger setup = SFA = better.
#88
Originally Posted by ga302p
I have seen both Ford solid axles and Chevy IFS both put through pure Hell. I have never seen either one break. Ive seen both their trucks lifted, jumped, hit rocks in deep mud bogs, you name it. I can say however, the Ifs will go through things the solid axle will not. The solid axle is stronger, but Chevy's IFS is more than strong enough. The solid axle is overkill.
#89
I am a Diehard Ford enthusiast, but i must say that IFS systems ride a lot more comfortably than my leaf sprung solid axle. I haven't ever owned a Chevy (thank you God for blessing me with Blue Ovals) 3/4 ton or otherwise, but i have ridden in a few and after hopping out of those trucks and into my Super Duty, it feels like im riding a skateboard. But on the flipside of the coin, I have pulled several new/newer Chevys out of the mud that have broken a CV joint.
#90
