Is this a battery to battery charger? 95 E150 Mark3 Conversion
Setting up a second battery in my 95 E150 Mark3 Conversion and looking to add a battery isolator or DC to DC charger, but I think there may already be something similar installed... Is the part in the images below a battery to battery charger of some sort??? It's installed on the wall of the engine compartment right in front of the battery and connects to both battery posts. Looks like a low gauge yellow wire and red with light blue are connected also... I think there is an empty battery harness underneath but im not sure and don't have pictures of it. What do ya'll think?
That is a solenoid to switch on battery voltage to the accessory circuits that may be connected to loads by a conversion company. It supplies a 12 volt circuit to the 7pin trailer towing socket. There are other branches running down the left inside quarter panel. It wont work for combining a second battery to the van. Adding another solenoid is needed if you want 2 batteries in parallel while cranking and charging both while the engine is running.
That one caught me by surprise years ago, after being used to the short battery positive cable to the fender mounted solenoid. From there, the long battery cable to the starter was hot only when cranking. Easy screwdriver or pushbutton shorting the battery side to the energizing screw to spin the engine.
Then they put the solenoid pictured above to power the other solenoid on the starter below. ???? Now there is a permanently hot, fairly long, non-fused large battery cable snaked down to the starter. The diagram shows the starter motor right beside the battery and the solenoid that is actually beside the battery further away. Scale means nothing when following wiring diagrams. The gear reduction starter (PMGR) is a definite plus. I'll take that and live with the always hot starter cable.
My 1994 van came with the second aux/house battery installed and a continuous duty solenoid hidden underneath the driver's side battery, accessed by removing the headlamp and using the hole behind it. Cramped. A battery cable runs across the front top of the radiator to the aux/house battery on the passenger side. In my case, the aux/house battery solenoid is energized only with the engine running, to avoid draining both batteries if the key switch is left on.
Zacto, does your van have a battery tray on the passenger side? I actually prefer a continuous duty solenoid over an isolator due to the isolator's inherent voltage drop and I'm old and like electromechanical devices.
My charging voltage measured at the starting battery ranges from 13.9 to 14.8 volts. 130amp alternator. As long as the charging voltage rises to the high 14's, the paralleled system worked well until a 12v fridge showed up and I parked without much driving. I do not have the fuses seen in the diagram in the link below, to provide starting current from the house battery if necessary.
This link from another forum has enough info to make your eyes bleed.
https://expeditionportal.com/forum/t...-for-50.77503/
No battery tray on the passenger side but I think there is one on the driver side. It looks a bit small for a battery though. I'll get under her for some pics when I can.
Going with a smart isolator over a solenoid. Smart iso doesn't cut in until 13.3V and cuts out at 12.8V
