6.2 or 7.3 for slide-in camper?
Bottom line: For that weight it doesn’t matter which engine you go with. None of them will feel it back there. I tow my 4,000 pound boat + trailer with my Expedition EL - 5.4L Triton/6R80/3.73 and I have never lacked power to exceed the speed limit with it in tow. The Expedition really doesn’t feel it back there besides braking, so an F-250 will not be phased in the least. Anything under 4,000 pounds will be a breeze for any of your engine choices. For what it’s worth the 6.2 has more torque everywhere in the rev range than the 5.4, so that engine will do everything you need. Whatever choice makes you happy in this case as they are both overkill.
If you feel it’s a slug with 3.73, it will be marginally better if none at all than if it had 4.30. I’ve had both, guys make the 4.30 sound like it turns the truck into a monster, it doesn’t. Slight improvement, maybe? I couldn’t tell. Other than on takeoff, same power once moving.
I'm also curious about the performance of the 6.2 with the 10-speed, but haven't seen any real world reports of this combination yet. I have to decide how long I can wait for more information before I have to pull the trigger...
Definitely 4x4 with 4.3 axle ratio. If i didn't need a long bed, I would probably also be considering the Tremor package. The camper is a Four Wheel Camper Grandby pop-up. Dry weight is ~1800 pounds, but I tend to travel heavy with photo equipment, etc, so looking at F350 for a safe payload margin. Supercrew over crew cab for a little shorter wheelbase offroad.
Thanks,
-Scott
Thanks,
-Scott
Selecting the slightly smaller 275/65R18E AS tires will cost several hundred pounds in GVWR and payload. The rear GAWR takes the big hit, losing 450 lbs.
The certification- and payload labels on the driver side B pillar will be based on the truck’s as-built configuration.
HTH,
Jim / crewzer
OK. Either way, make sure you spec the optional 275/70R18E AT tires to help achieve the maximum GVWR and payload specs.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
#29
#30
My Lance weighs similar to yours, I ordered a 7.3. A 6.2 will easily handle the load, but once you start climbing in altitude, you’ll wish you had more power. You might want to start towing something in addition to hauling the camper too. I wanted the capacity to haul the TC and pull maybe a 10,000 lb boat. The 7.3 should be able to handle it fine.
