Check engine light
Old Feb 21, 2001 | 10:09 PM
loudfords's Avatar
loudfords
Check engine light
My 87 F150 has no check engine or engine light. The little windows are there in the dash but there are no bulbs or holders behind them. Is this normal for these trucks or am I maybe missing a code or two my computer might want to be telling me?
Thanks.
1979 F150 Custom: 75 351W, Edelbrock & Holley
1987 F150 XLT Lariat: 88 351W EFI
Chevy 454: waiting for a truck (Mazda?Nissan?)
Old Feb 21, 2001 | 11:51 PM
jakegypsum's Avatar
jakegypsum
Check engine light
Your truck should have a check engine light on the left side of the steering wheel. It should be below the dash lense and not incorporated within the speedometer guage cluster.
Jakegypsum // Ford fleet, soup to nuts.
Old Feb 22, 2001 | 11:16 AM
loudfords's Avatar
loudfords
Check engine light
It's there but there's no bulb or holder behind it at all.
Old Feb 22, 2001 | 11:27 AM
PAUL_2's Avatar
PAUL_2
Check engine light
Its an 87 truck with a 88 351 , Correct ? The usual cause of the missing bulbs is someone removed them because they were on & they didnt want to fiddle with whatever the problem may have been . Do you know what engine originally came in the truck ?
Old Feb 22, 2001 | 02:46 PM
loudfords's Avatar
loudfords
Check engine light
I did the engine change myself. It was originally a 302 and is still running on the 302 computer. There are no obviously cut wires or anything. If it had a light before, surely a bulb holder would still be in there? It would be a lot of work to go that far to hide something. The truck has a build date of March 87. It had been run on propane before but I don't see that as being any reason to remove the check engine light.
Old Mar 6, 2001 | 07:40 AM
Avanti's Avatar
Avanti
Check engine light
Old Mar 14, 2001 | 08:14 PM
slamedf150's Avatar
slamedf150
Check engine light
i have an 87 with 302 and mine dont have a light or holder either
Old Mar 15, 2001 | 11:29 AM
loudfords's Avatar
loudfords
Check engine light
I found out on a later thread that the bulbs insert into printed circuit board. I added bulbs to mine but they're not lighting up at all. I don't know if its a different style bulb or not, I haven't had time to check yet.
