12v source
Old Nov 15, 2019 | 08:20 AM
1320stang's Avatar
1320stang
Side topic, if you're wanting to add a relay for an electric fuel pump, fog lights, compressor, etc. and you want it to only work off the key, is that the connector you want to use? Or is there a lower voltage keyed source?
I ask because I'm adding an electric fuel pump (there will be a thread) and I want the switch to control a relay, but only want power to the switch when the key is on or in accessory.
Mine is a '73 and I'm not seeing wiring diagrams for it, however I do have the dash out so I have access to all of it.
Old Nov 15, 2019 | 09:24 AM
angry_fred's Avatar
angry_fred
Wiring diagrams are here: https://www.fordification.net/tech/wiring.htm
Easiest switched power to drive a relay in the cab is the radio power
Easiest switched power under the hood (verify this one) is one of the terminals off the starter solenoid
Old Nov 15, 2019 | 10:33 AM
1320stang's Avatar
1320stang
1973 - COMING SOON
Cooter55
May 2, 2018 06:49 PM
npccpartsman
Aug 24, 2012 06:06 PM
53redford
Dec 31, 2005 11:42 AM
NJ239Y
May 22, 2004 07:34 AM
BEEBZ
Sep 21, 2003 04:55 PM
