Need help.
Old Aug 9, 2019 | 05:09 PM
Jeremy Brooks's Avatar
Jeremy Brooks
Need help.
Hey everyone, so I just recent purchased this truck and have been pouring over it trying to diagnose all the various issues with it. I have found a component that I'm not sure what is, or where the lines go to but it seems one of the connecting lines is just missing. Can anyone tell more about this component and the lines that run to it.
Old Aug 9, 2019 | 05:21 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
that is the fuel Lift Pump .. IF it has the lines disconnected then maybe the previous owner installed an electric pump closer to the Fuel Tanks
Old Aug 9, 2019 | 05:41 PM
Jeremy Brooks
That would make sense for why this is connected here. Is the way this is setup harmful for operation of the vehicle?
Old Aug 9, 2019 | 11:26 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I would be more concerned with that bare red wire shorting to something.... but if it ain't broke don't fix it
Old Aug 10, 2019 | 12:02 AM
solanum's Avatar
solanum
The electric pump is actually a popular modification, and most people who have done it speak highly of it. There are a lot of good reasons to have it there.
There is what appears to be a carburetor inlet fuel filter in the line before it, that needs to go. Diesel fuel has way more crap in it than that filter was meant to take out, not to mention the filter is designed to work in a pressurized line but is on a suction line. No bueno.
That pump doesn't really need a filter before it anyway, and the stock filter is perfectly adequate for protecting the IDI fuel system (about as precise as a hammer, compared to modern diesels). You can add an aftermarket filter head before the pump, but adding an extra maintenance item and about 6 more potential leak points is really not improving anything. These engines commonly go for 800,000 miles- that's 50,000-80,000 gallons of fuel- on the original fuel system, with the stock filter alone.
Old Aug 10, 2019 | 12:12 AM
Jeremy Brooks
That is the power cable for the pump, they have the ground and power connected to the terminal posts on the battery.
Old Aug 10, 2019 | 05:18 AM
tjc transport's Avatar
tjc transport
i ain't rite
would be more concerned with the cheap electric pump being used failing.
those pumps are not made for diesel use and normally do not last very long.
Old Aug 10, 2019 | 10:53 AM
RaymondIV's Avatar
RaymondIV
Right, nothing wrong with the good old Carter mechanical lift pumps that came stock. They were used on Ford, Chevy, IH, etc. gas engines for decades. Mines lasted for over 20 years.
Old Aug 10, 2019 | 11:48 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
OK I get it, so you have to open the hood and connect the pump to start the truck then when you shut the truck off you have to open the hood to disconnect power from the pump....... or it just gets power all the time and you rely on the pump's internals to keep is shut off while it has full pressure.....
while it is ok to use it for diesel because Holley says it is rated for Diesel it wouldn't be my pump of choice and it is not mounted to Holley's Specs.
I wouldn't expect the filter to last too long in the diesel world... and another thing is that Pump does not have a Reverse Flow check Valve so you could have drain back with it. with all that said, it's not one of the cheapest pumps I've seen folks use on the IDI's ... I've seen much worse
https://www.holley.com/products/fuel...s/parts/12-427
I prefer the good old rebuildable Carter Mechanical pump, they work fine and last years <<== but that is just me.. everyone has their own opinions
