OEM puck system measurements.
I was just looking at mine while you posted this & the front of the bed looks really close to the cab. Did you have to lift & then slide the bed back? It doesn’t look like it will lift high enough to slide a 4x4 in place without moving back & then what about the rear plastic trim piece under the tail lights between the bumper?
Which torx bolts are you referring too? The 2017 & newer trucks use that funky EP 24 torx socket for bed bolts & the old trucks used a standard torx bolt for the bed bolts that’s under a T-55 for sure. I don’t remember what the size was but my set only goes up to T-55 & I tightened one of my bed bolts about a month before I traded it in.
Interesting, glad you mentioned those because I don’t have my kit yet & was unaware. Not sure of the size but my Snap On set only goes up to 55, maybe try a Napa auto parts store?
I’m doing the same install on my ‘13 but I also have a large Westward torx bit kit. I believe you should be looking for a ‘plus’ size, designated by 50IP, maybe TP50, etc. It’s a significant amount of more meat on a plus-sized bit/bolt, check the image for the difference.
For what it’s worth, I’m installing the Reese aftermarket puck kit on my truck and the bit used was T50IP - meaning internal plus size 50.
Hope that helps.
Hope that helps.
#29
Hope that helps.
Hope that helps.
#30
