Spark plug change and now truck is running rough
  #31
Old 04-20-2019, 09:51 AM
tigger4u44's Avatar
tigger4u44
tigger4u44 is offline
Originally Posted by biasvoltage
Knocking - I hate to envision a bad scenario, but is it possible that something fell in one of the spark plug holes, or one of the old spark plugs lost a sliver of insulator or an electrode when you pulled them?
I checked all the old plugs carefully last night and they are all intact from what I can tell. I'm hoping anything falling in there is not the case.
  #32
Old 04-20-2019, 01:54 PM
72rtchallenger's Avatar
72rtchallenger
72rtchallenger is offline
Get number one piston to top dead center and see if rotary button is pointing to number one spark plug wire on distributor cap .
Check coil .
Does it have points ? check those if it does
  #33
Old 04-20-2019, 07:45 PM
tigger4u44's Avatar
tigger4u44
So I checked the timing today and everything looked pretty good. The knocking from what I can tell is coming from the valve covers, maybe the rods or valves. Here's a video link of what it sounds like before I pulled the drivers side valve cover. Once that was off I didn't see anything alarming to speak of so tomorrow I will pull the passenger side as well.
https://pin.it/zlbxhelkyldng5
  #34
Old 04-21-2019, 06:15 AM
niko20's Avatar
niko20
niko20 is offline
I don't think we can view that unless we have some pinterest account?
  #35
Old 04-21-2019, 09:30 AM
tigger4u44's Avatar
tigger4u44
Dang it. Sorry, is there a better way to add video?
  #36
Old 04-21-2019, 10:57 AM
tigger4u44's Avatar
tigger4u44
Ok this video should work
  #37
Old 04-21-2019, 11:56 AM
caravaggio2000's Avatar
caravaggio2000
caravaggio2000 is offline
Yes, that is super loud.
I have no ideas really other than that maybe previously there was a cylinder that wasn't firing that is now that you replaced everything. But, you said you pulled one plug at a time and there was no difference.
I might be wrong, but it seems like your vacuum advance is at an odd angle (which maybe means the whole distributor is turned wrong). I though they were supposed to be almost pointing straight towards the front like this...
  #38
Old 04-21-2019, 03:25 PM
niko20's Avatar
niko20
niko20 is offline
That sounds eerily similar to some videos I found last week of what your engine sounds like when a spark plug is "blown out" and the cylinder isn't sealed all the way. (Like if the spark plug hole was open or leaking).
Here's a guy saying he had bad compression because of a bad spark plug and he had knocking because gases were getting past the plug.
Seems oddly similar due to the fact the you changed the plugs just before this happened. Like, perhaps one of them isn't sealing correctly.
  #39
Old 04-21-2019, 11:04 PM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
Sounds like lifter clack it is valve train for sure though.
  #40
Old 04-22-2019, 07:30 AM
Ozzie H.'s Avatar
Ozzie H.
Ozzie H. is offline
It sounds like something in the valve train. You could try to narrow it down with a stethoscope or just remove the cover and look for a problem.
  #41
Old 04-22-2019, 07:57 AM
niko20's Avatar
niko20
niko20 is offline
He did already remove the cover and look, he said it looked normal
  #42
Old 04-22-2019, 08:33 AM
Ozzie H.'s Avatar
Ozzie H.
Ozzie H. is offline
I didn't hear about him removing the passenger side yet, but if both sides are O.K. then he should use the stethoscope to try to isolate the source of the noise. That's definitely something that needs attention.
  #43
Old 04-22-2019, 01:35 PM
John89's Avatar
John89
John89 is offline
I would pull and check the plugs again and attach a nozzle and some clear vinyl tubing to a shop vac and see if anything fell in. (Twig, acorn etc...)
You might also check to make sure it is not coming from your PS pump or anything else that may have been bumped while you were working.
  #44
Old 04-22-2019, 04:12 PM
tigger4u44's Avatar
tigger4u44
I've seen the vacuum advance on other 390 engines in almost the same position as mine. Prior to the spark plug change and compression test it was running good so I'm thinking the vacuum advance position is fine.
  #45
Old 04-22-2019, 04:14 PM
tigger4u44's Avatar
tigger4u44
I'll give all this ANOTHER look... sigh
Quick Reply: Spark plug change and now truck is running rough
