Next steps????
Old Apr 7, 2019 | 08:10 AM
AnotherChef's Avatar
AnotherChef
Next steps????
So, my first goal has been achieved. She runs, not very well, but she runs. I dont know what to do next.
1. Do I go ahead and get her running great by replacing intake, carb, timing set and maybe distributor
Or
2. Get the brake system in good shape?? I will have to basically replace everything except the booster!!
Currently it wont stop if it runs but if it doesnt run then why worry about stopping.
Old Apr 7, 2019 | 08:40 AM
Dave145's Avatar
Dave145
Makes no sense to make it run of it can't stop. Tack in the fact you usually have to test drive it to dial it in, and most will agree making it stop is #1 priority.
Old Apr 7, 2019 | 08:43 AM
73GreenBean's Avatar
73GreenBean
Well not sure if a budget is of concern but I'd do whichever is cheaper first so probably the brakes...also it might suck just a little to have a great running truck that you're excited to take down the road but can't because of a bad brake system. Just my .02 I like the security of a dependable brake system
Old Apr 7, 2019 | 08:59 AM
LiveFrom1977f150's Avatar
LiveFrom1977f150
Brakes for sure. These trucks are great modern day work horses for weekend work. You want to be able to load up the bed and haul some payload with them. Brakes are probably the most vital part of that. Plus you may decide to get the vehicle inspected to drive regularly on the road. Engines running rough generally still pass.
Old Apr 7, 2019 | 09:05 AM
TXTrailerdaddy's Avatar
TXTrailerdaddy
Make it stop. Make it steer. Make it run. In that order.
Old Apr 7, 2019 | 11:34 AM
AnotherChef
After a few YouTube videos I was able to get her to idle a bit better. So, I guess I'll do the brakes first.
(Disclaimer) Not sure if yall allow videos but here she is...
Watch "1976 Ford 460" on YouTube
Old Apr 7, 2019 | 02:50 PM
John89's Avatar
John89
Ditto on brakes first. If you plan on replacing the steel brake lines (which you should), get a complete kit. I did mine: all rubber lines, rear steel lines, front steel lines and ended up spending about 75.00 that I shouldn't have. Since I didn't get a kit, I used stainless braid to go from proportioning valve to the rear axle.
Old Apr 7, 2019 | 11:08 PM
meangreen92's Avatar
meangreen92
Sounds like it's running at least half-way decent!
Add another vote for brakes - it's just common sense. I know the allure of a new intake and carb are much stronger, but there probably aren't too many feelings worse than having no brakes when you need them...
Old Apr 8, 2019 | 06:56 AM
AnotherChef
I think I have my list put together to get the brakes finished first. If I can keep her running enough to move, in and out, of my shop; I'll be happy.
Thanks for keeping me on the right path!!!
Old Apr 9, 2019 | 09:04 AM
speedfreak78's Avatar
speedfreak78
That's way too long of a run for flex line in a braking system. The only place you should run flex lines is at the front calipers and the line to the rear axle. They should be just long enough to have a little slack with the suspension at full drop.
Old Apr 11, 2019 | 09:16 PM
AnotherChef
I have a pile of shinny new brake parts and hard lines in the shop!!! Just need a valve block and I'm good to go. Hopefully I can find one tomorrow.
Old Apr 11, 2019 | 09:36 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by TXTrailerdaddy
Make it stop. Make it steer. Make it run. IIn that order.
I concur with the above.
... add brake lights, turn signals, n headlights to the list.
sweetpete
Sep 7, 2024 12:39 AM
TN Vol
Jan 25, 2019 05:41 AM
WQ59B
1947 and Older Ford Trucks
16
Feb 12, 2017 09:51 PM
Joe Puleo
Large Truck
Mar 28, 2016 08:32 AM
freezeplug
Jun 25, 2003 01:39 PM
