Decode Vin Help- Y engine code?
Old Mar 22, 2019 | 10:39 PM
ThinkItBuildIt's Avatar
ThinkItBuildIt
F10YD803091 is the door tag warranty code. I can't make sense of the Y for engine type HELP!!
F10 the Series: F100
Y: wtf?
D: Dallas - yes likely as it's a Texas truck
803091: consecutive unit number
115 Wheel base, she's a shortie
B: color code Turquoise - yes
F100 - yup
C81- conventional cab in green vinyl - yup
C: Manual 3 light duty
08: axle code 3.5-3.3M
5000 GVW
172 hp @ 4000rpm
District code #62: Houston
My misunderstanding stems from the Y code. I'm the 3rd owner and I knew the 2nd owner, neither of us swapped the engine. according to Decode Your '65-'66 Ford Truck VIN Tag - FORDification.info - The '61-'66 Ford Pickup Resource the "Y" is a 1966 8cyl 352 cid 2v 208hp@ 4400 rpm. but the tag says 4kRMP with 172 HP, which seems low for a V8.
So, is the Y correct? Did it start live as a V8? what else can I check? I'll look at the frame code tomorrow in case the door was replaced some time.
Old Mar 23, 2019 | 12:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ThinkItBuildIt
F10 = F100 2WD
Y = 352 2V (D was used in 1965 for the 352 2V).
D = Dallas TX Assembly Plant.
803091 = 1966 (edit: assembled January 1966).
115" Wheelbase.
B = Caribbean Turquoise.
F100 2WD, 5000 lbs. GVWR
C81: C = Medium Green Crush Vinyl & Medium Green Cody Pattern Woven Plastic // 81 = 81B Custom Cab.
C = Ford type 3.03 3 Speed Manual all Synchromesh Transmission.
08 = Ford 9" Rear Axle / 3.50-1 / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
62 = Houston TX Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Mar 23, 2019 | 01:35 AM
ThinkItBuildIt
Thanks! Here I was thinking I've spent the past few years restoring a 1965 hahaha maybe I'll hunt for the proper engine. Thank you again for your support on this forum, you are amazing.
Old Mar 23, 2019 | 02:51 AM
NumberDummy
It's a 1966.
The dead bang give-away is the Y VIN engine code and the Numerical Sequence of Assembly (803091 - last 6 digits of the VIN) that decodes to a 1966 assembled January 1966 (edited into post #2).
Correct V8 for 1965/67 F100/350: 352 2V
4th digit of the VIN is the engine code. D = 1965 352 2V // Y = 1966/67 352 2V
Old Mar 23, 2019 | 09:58 AM
BarnieTrk's Avatar
BarnieTrk
TIBI,
I know you mentioned you've been working on this truck for a few years now, but have you ever compared the VIN stamped on the frame to the VIN on the door tag? Maybe you should check to ensure they are the same....sometimes doors get changed out but the owner does not exchange the VIN door tag. You could have a '66 door on a '65 truck............ it's worth checking if you haven't already......although it may not make much difference to you if you aren't doing a concourse-correct rebuild.
I know it happens because I have had one truck without any door tag and another with two different VINs , frame vs. door numbers.
BarnieTrk
Old Mar 24, 2019 | 12:46 AM
ThinkItBuildIt
F10JD638359 is what is on the frame. It's funny I've never taken notice of the numbers anywhere on the vehicle. The "6" of the warranty # is difficult to read. Engine says C5AE-6015-F then a few other digits... "?A14" I dont know what the first digit might be. On the transmission there is 5A12 stamped separately then two lines: G5AR with 7009 below it. The rear diff has 5A9 5A11 DIFF and 26 stamped in various places. I have photos of all those if I'm not being clear.
Old Mar 24, 2019 | 02:34 AM
RangerMercMan's Avatar
RangerMercMan
Your frame VIN is stating it is a 1965 and I believe the J engine code is a 240 straight six but could be the 300 Big Six. D would be a 352 V8
Old Mar 24, 2019 | 02:38 AM
NumberDummy
It has to be a 6, because if it was a 5, it would be a 1964.
"?A14" I dont know what the first digit might be. On the transmission there is 5A12 stamped separately then two lines: C5AR with 7009 below it.
F10 = F100 2WD // J = 240 1V I-6 // D = Dallas TX Assembly Plant // 638359 = 1965, assembled January 1965.
?A14 = January (A) 14, 196?
5A12 = January 12, 1965 (5).
5A9 = January 9, 1965.
Old Mar 24, 2019 | 10:59 AM
ThinkItBuildIt
Great help NumberD & RangerMM! Seems like there is conclusive evidence that the door was replaced at some point, and that the engine, trans & rear dif are all original. From what I understand, the "A" code on the engine means 240 but it is possible that it could be a 300. However, not likely. Furthermore, the surest way to check is to measure the piston travel. I think I'll do that while my gaskets are in the mail, and the manifolds await reassembly. If I come across anyone that re-manufactures door tags I might get one made.
Old Mar 24, 2019 | 12:01 PM
RangerMercMan
Marti Auto Works can apparently reproduce your door tag given all the info you have. I am in Canada so I cannot help you with him.
Old Mar 24, 2019 | 04:05 PM
BarnieTrk's Avatar
BarnieTrk
TIBI,
It appears that somewhere along the line someone updated the brake master cylinder on your truck as well. A '66 truck would have originally been equipped with a single pot reservoir unit. Your photo depicts a two reservoir unit. This update is a highly encouraged change as it makes for a much safer truck. The dual pot master cylinder units came in '67 and later model trucks.
BarnieTrk
Old Mar 24, 2019 | 04:21 PM
rturcotte13's Avatar
rturcotte13
Need help decoding my wifes "65" F100 Warranty tag reads as follows. F11DE613717 any help would awesome looking to start the restoration of it in the coming month need to know what we are dealing with. WB 120, Color WM, Model F110, Body B81, Trans N, Axle 08 thank you.
Old Mar 24, 2019 | 05:42 PM
NumberDummy
Originally Posted by rturcotte13
Need help decoding my wifes 1965 F100 Warranty Plate reads as follows.
F11DE613717 // WB: 120 / COLOR: WM / MODEL: F110 / BODY: B81 / TRANS: N / AXLE: 08 / MAX GVW LBS: 5600 / CERT NET HP: 172 / RPM: 4000 / DSO: Omitted
F11 = F100 4WD
D = 352 2V
E = Mahwah NJ Assembly Plant.
613717 = 1965.
120" Wheelbase.
WM: W = Medium Blue / M = Wimbledon White.
F110 = F100 4WD, 5600 lbs. GVWR
B81: B = Medium Blue Crush Vinyl & Medium Blue Ladder Pattern Woven Plastic / 81 = 81B Custom Cab.
N = New Process 435 4 Speed Manual Transmission.
5,600 lbs. Gross Vehicle Weight Rating.
Old Mar 24, 2019 | 05:50 PM
NumberDummy
From what I understand, the "A" code on the engine means 240 (1966/74) but it is possible that it could be a 300 (B = 300 1-6).
J = 1954/64 223 I-6 // J = 1965 240 I-6 // A = 1966/74 240 I-6 // B = 1965/79 = 300 I-6.
Old Mar 25, 2019 | 05:02 PM
ThinkItBuildIt
If I get a reproduction made by Marti Auto Works, is there any way to confirm the trans, axle and D.S.O number?
The trans is a 65 3 speed manual so that would be an "A" code
The Axle Code and D.S.O # I'm not sure. All I know is it's a 9" ford rear differential.
