In the Market for a new WD Hitch - Any suggestions?
Received 6,844 Likes
on
I'm using the Andersen WDH with the 3" shank. Here's a link to their web page: https://andersenhitches.com/Catalog/...tion-kits.aspx
I did a review of their hitch on FTE and it can be found here: https://www.ford-trucks.com/forums/1...ion-hitch.html
My truck has a three inch receiver, I don't know what yours has. If you have a three inch receiver, for the most part, a two and a half inch shank is the largest you are going to find. The Anderson and Gen-Y are the only exceptions I know and I'm not really sure how the Gen-Y works.
Because I move my WDH between campers I bought something that was very easy to install and set up. It only takes me a couple minutes to attach my WDH to a camper that's never had one on it. But that does limit me to the 2.5" shank, which is a problem with the 3" receiver. I still got enough movement with the reducer sleeve that the hitch pin hole started to round out on the receiver. Since I am reasonably sure I'll never buy a 3" shanked hitch my solution was to weld the reducer into the receiver to eliminate that slop.
If you have the 3" receiver, I strongly suggest going with the Anderson WDH and 3" shank. The use of reducers is just not a satisfactory solution.
What do you define as "the larger shank"?
on
To me, their biggest selling points are easy set up, easy to use, and safer than traditional bar and pin latches.
It's a good idea to "match" the hitch WD rating to the actual tongue weight. If your hitch is too "heavy" for the actual weight, it will never handle right.
I share all this for the purpose of pointing out that it isn’t critical to match bars and weight. I wouldn’t use under rated bars, but if the bars are rated higher than the maximum tongue weight you’ll be fine.
