Recommended EGR plates and DPF delete kits
#47
This replaces the DPF only and fits between the down pipe and factory resonator. Crawl under your truck and look at how the exhaust is routed. The section after the DPF with the resonator can be left in place if you want, and put on a new tip just for looks. It will rumble.
#48
#49
It's 2 bolts at the front pipe connection, 3 bolts at the rear pipe connection and the 3 hangers. You replace with your selected pipe and the rest remains factory. Unless you want to change the rest, which is doable. Your decision as to how much you change. On the truck I've been referring to, he only did the mid pipe and left everything else alone. He seems very pleased with it. I like the way it sounds and it runs really, really well.
#50
#53
For those running the 5" exhaust Turbo back or down pipe or just straight pipe where the any complications such as Not being able to keep a spare tire located underneath from installing. My tires are 35x12.5x20 , the spare tireI reais 35x12.5x18 On the factory steel rim I don't want to not have the spare tire with me . I read somewhere that if you run a 5" exhaust that you cannot keep your spare tire.. Thank you I'm just trying to figure everything out because as of the 5th of next month I am purchasing everything.
#54
#55
#56
#57
#58
so I finally took a look and there is enough space for a 4 or 5 inch . My question now if you don't mind is with the 4 inch race pipe and resonator how are your egt's ? Also any drone because this is my daily driver and the wife is with me at times ?
#60
I have a 5” and all is well. A 35/12.50/18 spare should fit.
When towing up MT Eagle with 20,600LBS and my foot to the floor doing tune testing, it never went over 1100°s. EOT was 250° and trans was 235°. Patriot 450 tune. Drone is noticeable with a 5” and no muffler. It’s bad when towing.
