Runs Rough, No Codes
Old 08-10-2008, 02:35 PM
reino134's Avatar
reino134
reino134 is offline
Originally Posted by pfogle
I would replace the distributor cap, I have had brand new ones cause the problems you are describing. It may look alright per a visual inspection but, can indeed be bad. I would replace it and the rotor with an expensive set from napa, as they seem to be the best. I have learned that it does not pay to go the cheap route on ignition/electrical parts. I would also check to make sure your brake booster isn't leaking, and make sure all the vaccum lines on the engine are ain good shape. I had a few that I thought were good until I went to pull them off to check them, and they crumbled.
I cant figure out my issue either. Read an interesting idea in this post. vacuum leak in brake booster. It sort of sounds like I have a vacuum leak inside my brake booster. How can you confirm this? It is not causing any type of braking problems.
thanks
danmm7
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
22
05-28-2018 12:53 AM
TJCOS
1997 - 2003 F150
08-13-2016 07:28 PM
RedDevil460
08-12-2016 06:07 AM
GotLift
01-14-2016 03:17 PM
Quick Reply: Runs Rough, No Codes
