Nebraska's 2019 January babble thread!
#646
Not just there John. Wind is howling here. temps are wind chill 0* f
Was going to do a little work on my Eddie Bauer truck, but it's too cold to even open the shop up!
#647
Received 4,214 Likes
on
#648
I went to Jr College in Canton, NY (near the St. Lawrence river) years ago. We had one week of -35*. The next week we had a heat wave of -5. So warm you didn't have to wear a hat....
#649
on
It actually don't feel too bad out there now but I don't feel like crawling under a truck in the driveway. I tried having the wife crank the key on while I smacked the starter but can't get a proper swing to jar the solenoid. If I could get it started I'd drive it in the garage and let it warm up...
#650
Have you tried jumping the solenoid ? Battery cable to small connection? We used to be able to take the solenoid apart and reverse the round copper washer like connector that would provide power from the battery cable to the starter.
#651
on
I could likely put a screwdriver from the main lead coming from the battery to the starter from that to the solenoid. That's won't fry anything else in the system will it . Bad enough I need a new starter...lol
#652
That's the way we would "jump" the starter, John
I've got some starter brushes and bushings if needed...however they are in NY
#653
on
Maybe if I convince myself to get in the mood I'll crawl under the truck tomorrow. I guess the key would be in the run position..?
#654
You can jump a gm starter like a ford solenoid with a screwdriver.
Be careful tho, I saw a guy run over his own leg one time doing that, it was in gear, and the truck started, ran right over him
#655
on
#656
It will still work, John. Best have someone in the vehicle, when leaving the key on.....unless your wife is mad at you.
#657
on
I think If I can bump the starter it might start right up, could be corroded contacts and not allowed current to flow. I'll get under there tomorrow with a screwdriver..
#658
Probably a set of brushes John. They don't last forever
Unless the windings have a short, you're probably better off rebuilding it yourself.
New rebuilt stuff is absolute junk
#659
on
#660
As Charlie said, it's not too hard to rebuild (brushes, check play in end bushings, replace and lube if needed, and contact washer in solenoid) With your talents, you can do it.
https://www.zoro.com/acdelco-starter...SABEgJYffD_BwE pricey
https://www.ebay.com/p/Starter-Motor...2699202&chn=ps
the above kit shows the solenoid washer I mentioned
