Front axle swap
Old 10-26-2018, 10:51 PM
SumDayDryvr's Avatar
SumDayDryvr
SumDayDryvr is offline
That is interesting information Wayne as I have two f100 axles out here now. Would just need to find the 8 bolt hubs. Thanks
Old 10-26-2018, 10:58 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,451 Likes on 1,398 Posts
There is an 8 lug disc brake conversion for these trucks you may look into, if you have everything else and just need hubs and brakes.
Old 10-27-2018, 08:18 AM
SumDayDryvr
Haven’t had a chance to talk to my son yet but I will have to see which way he thinks we should go.
The disc brakes should give greater stopping power. Would they need to be power brakes for the kit?
Sounds like we could be sliding to the dark side now, although they do have cookies. LOL
Thanks Wayne.
Old 10-27-2018, 10:07 AM
52 Merc's Avatar
52 Merc
Thanks Wayne.
I would recommend it. It can all be fitted under the floor and use the stock pedals so you could retain the stock look with modern benefits and driving ability. It would be a worthwhile update, imho.
Old 10-28-2018, 08:14 AM
SumDayDryvr
I think it was posted somewhere that these old Y blocks don’t produce enough vacuum for power brakes and they suggested using a large plastic pipe to store it.
First things first, going to look for 8 bolt kits to see if I need to find hubs for installation.
Thanks for the information.
Forgot to mention that my son thinks that the power disc brakes are a good idea.
Old 10-28-2018, 04:03 PM
52 Merc's Avatar
52 Merc
Here is the disc brake kit I was thinking of. It's been used successfully by guys here before, which is why I remember it. It does say you need to use your own hubs, and I'm sure there's someone here that can hook you up. You could check with Kevin 'bigwin56f100' he deals in 53-56 Ford truck parts and likely will have a set of 8 lug hubs.
https://www.tsmmfg.net/ford-truck-8-...-kit-1853.html
Old 10-28-2018, 06:25 PM
SumDayDryvr
Thanks. I was checking that company out earlier and it looked like it was well made. Was hoping that we can find some 8 bolt hubs a little closer as I see a lot of f250 trucks coming out of the west so there should be a few around here.
I will keep Kevin as a backup plan .
Old 01-12-2020, 04:36 PM
Powerstrokin_350's Avatar
Powerstrokin_350
Powerstrokin_350 is offline
Hey did you ever solve this dilemma on your truck? I have been figuring out what’s the easiest or best to retain some stock-ness but do away with the 6x7.25. Not to mention my Timken 150 rear and it’s 5.14s. (Mines a 1953 express bed)
enter 1961-64 F250 2wd. Maybe 57-60. 8 lug, the front axle fits in place, use the rearend from same truck. Now I have 8 lug, non obsolete brake parts on all 4 corners, more driveable gearing, and with dually conversion spacers i could run a later model dual wheel rim if I want that factory appearance. But I dunno yet what I’ll do. So did you decide? Lol.
Old 01-12-2020, 06:41 PM
SumDayDryvr
We decided to get a stirling 10.25 rear axle which is from a 76 F350 because it is easier to work on than the Dana rear axle, don’t need to pull the axles to replace the brakes. It may be a little wider but we are hoping to make it work, it was originally a dually.
For the front axle we had the original front hubs redrilled to the same 8 bolt pattern and used the f250 drum and shoes. We haven’t finished yet so not sure how it will turn out.
There are some great ideas put forth in this thread. Hope you find a good direction for your build
scl009
1999 to 2016 Super Duty
19
12-04-2018 09:09 AM
GreaseMonky
08-20-2014 09:10 AM
TheWedge1
03-23-2012 02:03 PM
markfuga
Large Truck
06-13-2011 04:33 PM
moosebrew
07-06-2010 09:04 PM
Quick Reply: Front axle swap
