Oil cooler replacement
I noticed a small coolant leak at the front by the oil cooler. Removed it last night. Now I swear the back black O ring was not on the cooler or stuck in the oil filter adapter end. From what I understand if that was truly missing the coolant would be inundated with oil and a slew of other issues. I have a new cooler and Onring kit ready to go back in.
I had to reseal mine once because it started pouring oil out on the ground. The o-rings were all there but very brittle. I do remember reading, and you probably already know this, that the ends should be squeezed back onto the cooler body as opposed to tapping it together with a mallet. I think I used a 2" ratchet strap to pull mine back together and it never leaked again.
I know it cost more this way but I will know they are new and ready for service. I have new water pump, trans, and a slew of other maintenance items. I plan to tow with this rig for a long time😁
No need to use a strap to push/squeeze the heads back onto the cooler tube. I stand mine upright with the bottom end on a scrap 2x4 and just press downwards with my body weight. As long as you completely lube the o-rings with oil or a tiny bit of grease, they go back together nicely without the complication of straps, presses, clamps, etc. I've done several that way, and it always works well for me. Before you ask, no, I'm not a small man, but I know of small skinny guys who have been equally successful with the same technique.
Stewart
