Will the SRW long bed of any 93 be a direct bolt on to replace a damaged long bed on a 1990 F350 Crew SRW 4x4?
What if any diferences are there in bed and tail gates?
What years will bolt onto the 1990 and will I be able to use the 1990 gate with that bed?
the '93 will bolt up just fine. the tailgates interchange from '87 to '96. actually the beds from '80 to '96 will fit, but the tailgates are different. also the taillights are different on'86 and older. -chad
87 f-250
" if you are going to have a bear, it might as well be a grizzly"
4.9 granny tranny 4.11 gears
