warped exhaust manifold
Old 09-23-2003, 04:44 PM
djmac's Avatar
djmac
djmac is offline
i have 2 leaking exhaust manifolds. i do not believe they were ever tighten up correctly by the po. i went to the exhaust shop and they were talking about the probability of the manifold being warped and having to be replaced. he claimed that was very common in the 460's case. he was talking around 900 to 1000 dollars. personally i think he is nuts but at any rate sounds like as much as i hate doing anything that has to do with the exhaust i going to have to do this myself. first question do manifolds frequently warp? 2nd question: if so can you stack the gaskets or is there a sealant that can bridge the gaps. any help would be appreciated.
Old 09-23-2003, 06:40 PM
ssap108's Avatar
ssap108
ssap108 is offline
i also heard that 460 motors frequently get exhaust leaks mine doesnt (factory, no gaskets) leak, but i did see some gaskets at kragen auto parts the other day that were extra thick and "guaranteed"not to leak...i would talk to a machine shop about resurfacing them alsojust my unprofessional opinion.
Old 09-23-2003, 09:44 PM
goofy173's Avatar
goofy173
goofy173 is offline
The manifold studs are known to break and open up the gasket. Ford even used different studs to replace them.
Old 09-24-2003, 06:40 AM
georgedavila's Avatar
georgedavila
georgedavila is offline
They're on ebay all the time.
