Oil spraying out of exhaust manifold
Yes one spark plug was especially clean. I will stick my borescope through the plug holes and see if I see coolant in any of them. As for the lean condition...even if there is excessive fuel, there is a higher ratio of air to fuel. If the mixture is way too rich to ignite, the oxygen and fuel from that cylinder will pass over the O2 sensor and O2 sensors only read oxygen. Since that oxygen was not burned at all, it would mimic a lean condition. I've read this in a couple places and it makes sense if you think about it. If it were to ignite, the oxygen would burn and there would be a rich reading. The injector from cylinder 1 is definitely stuck open a little bit. I can blow air through it but not the others. The filter baskets in all but one injector were completely deteriorated, so I'm assuming a piece of the filter or gunk from the fuel ended up in the injector. Most likely from changing the fuel filter a couple weeks ago.
Nicholas McKay
08-09-2018 03:15 PM
pboffroad
01-18-2013 04:28 PM
sasquatch999
23
10-23-2007 02:34 PM
