1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Anyone upgrade calipers?
Old 07-31-2018, 11:50 PM
jimmystoys's Avatar
jimmystoys
jimmystoys is offline
Originally Posted by Chuck-B
What SSBC model are you looking at? I go to their site, select 2013 from the drop down, then Ford, all I see is F450s, F550s and Mustang?
2012. There is nothing after 2012, of which mine is.
Old 08-01-2018, 07:41 AM
saratoga2011's Avatar
saratoga2011
saratoga2011 is offline
Originally Posted by jimmystoys
This sounds interesting saratoga. SSBC offers 25% more braking for their setup. I'm wondering how the new year Ford upgrade would compare with that?
Napkin math says the stock rotors on the 13+ trucks are 10% larger. Dunno how SSBC calculates their 25% so I can't say how it compares.
You won't find anything for the 2013+ F250/350 from SSBC because they chose not to offer parts for the 14.28" factory brakes.
Old 08-01-2018, 08:09 AM
leadmic's Avatar
leadmic
leadmic is online now
Has anyone done the 2012- to 2013+ conversion? I would like to know what is involved. I know the rotors and calipers would get replaced, but what about the hoses and master cylinder? Will the calipers bolt up or does the knuckle need to be replaced? Will the ABS still work correctly?
All questions that need to be answered.
Thanks for any input.
Mark
Old 08-01-2018, 09:40 AM
TooManyToys.'s Avatar
TooManyToys.
TooManyToys. is online now
Received 2,097 Likes on 1,421 Posts
I can't speak for the models past 2008, but with the change in the brakes from the '99-04 to '05-08 years that small increase in caliper piston sizes required a change in the master cylinder diameter to increase the volume of fluid for the larger pistons to keep the pedal travel in the desired range. But then that required also a change in the brake pedal ratio to maintain pedal effort to meet the FMVSS 105 target for stopping distance during the booster failure section. If not for more leverage the non-boosted hydraulic pressure would not have been enough at 150lb pedal effort.
A long way of saying if you increase the volume of fluid needed for caliper displacement you'll have a longer pedal. To compensate the pumping volume of the master cylinder needs to increase or you have longer travel. If you increase the diameter of the master cylinder it takes more pedal effort to achieve the same hydraulic pressure.
Way easier to bump up the coefficient of friction of the brake pad material, coming from a guy who worked in the friction material business.
Old 08-02-2018, 09:48 AM
jimmystoys's Avatar
jimmystoys
Mark
I was also wondering about this upgrade conversion.
Old 08-03-2018, 09:39 AM
Chuck-B's Avatar
Chuck-B
Chuck-B is offline
6.7 Weight Loss
Here are the $4,500.00 6-piston Calipers and Rotors for the 2013+ that I found - https://www.stillen.com/catalog/prod...category/1301/ Nice to dream
Old 08-03-2018, 11:24 PM
jimmystoys's Avatar
jimmystoys
That's brutal!
Old 08-04-2018, 02:21 AM
slownsy's Avatar
slownsy
slownsy is offline
Go back to original wheels and you will be over your problem.
Frank.
Old 08-04-2018, 06:46 AM
TooManyToys.
I never looked at his signature. Your brakes are over leveraged with those tires.
Old 08-04-2018, 09:01 AM
jimmystoys's Avatar
jimmystoys
Frank.
Yes I know. I hear it all the time. Your trucks too tall....You have too much power....Your hitch is too big...blah blah blah blah blah lol. If trucks were all stock, this website probably wouldn't exist. But I'll keep on look'n. Just like my trucks a little different.
Old 08-04-2018, 12:50 PM
TooManyToys.
I'll leave you with this blah, blah, blah. You might want to check out putting F450/550 axles and brakes under her.
It's like running 15.2K GVW with a 13k GVW truck.
Old 08-05-2018, 07:55 AM
Chuck-B's Avatar
Chuck-B
Chuck-B is offline
6.7 Weight Loss
You could probably find the whole set-up at a junkyard at a reasonable price and is really shouldn't be a killer conversion.
  #28
Old 08-05-2018, 09:14 AM
leadmic's Avatar
leadmic
Well you are welcome to change your truck in any way you like after all its your truck, but when you make said changes you need to be ready to spend the money to modify the other effected systems that your changes effected. Wilwood makes calipers and rotors to eliminate your brake issues for $4200.00. Or like was suggested you could put F450 axles and get bigger brakes, the downside is they are dully axles. In the end its up to you just be sure to make your truck safe for the rest of us sharing the road with you.
Mark
  #29
Old 08-05-2018, 10:11 AM
TooManyToys.
You can always get axles narrowed. Might not be cheap, and the next class up may not have the wheels.
Scrub radius is the best way to improve effectiveness. Going to a higher effectiveness, high thermal stability is the most cost effective. While the dissipated energy is still the same (weight of vehicle) it’s done at a slower swept speed with the stock size rotors, so clamped thermal temp can go up and you need more fade resistance. Overall temp does not go up.
Going to something like Hawk severe duty for towing/commercial could solve the issue, although the first cold stops can cause some puckering with this high metallic compound. From tests, cross drilled rotors don’t help this at all, from both reduced mass and interrupting the normal airflow through the vanes unless the rotors went through a specific design for the side stepping the flow. A standard design rotor drilled tends to pull less air from the center of the rotor and rotor temp can actually go higher.
  #30
Old 08-05-2018, 10:23 AM
jimmystoys's Avatar
jimmystoys
Lots of good options, I like it. My passenger front pads seem to be wearing slightly quicker than the driver side, unevenly I guess. So I'm just trying to see what options are available. I'm going to have it looked at on my next oil change. Change the oil every 5000 miles and rotate my tires too. I measured my pads in and out on each side. The passenger side is wearing quicker than the driver, so I'm preparing for possible brake work.
Quick Reply: Anyone upgrade calipers?
